P0304 cylinder 4 misfire
Old Mar 22, 2021 | 10:18 PM
Frozer860's Avatar
Frozer860
Been chasing a misfire issue for the past few days. 2006 MCS pretty much stock with about 105k on her. Started it up and drove half a mile then started running terrible. got 4 codes. Note that I have been driving with the 2096 code prior to this issue (but maybe it's the root cause?)
I started by swapping the spark plugs wires. No change. next I swapped the injectors around. moved #4 to #3 hoping the code would follow the injector. Still got the #4 misfire code. I also put all new o ring's on the injectors since I lost one.
Lastly I did a compression test. Rented one from the auto parts store. Each cylinder shows 130psi. Low, but consistent, based on my research. I also topped off the oil since it was a little low. Ran it a bit but still runs awful. Idle is really bad so I can't even drive it.
Looking for some advice on what to check next... Coil pack? Leak down? Swap plugs?
des.
Old Mar 23, 2021 | 08:16 AM
cooper48's Avatar
cooper48
Since the code remained on cylinder 4 after you moved the injector and spark plug wires, your next logical step would be to replace the coil or coil pack whichever is germane to your Mini.
Old Mar 23, 2021 | 12:39 PM
Frozer860's Avatar
Frozer860
Thanks, I will try that tonight.
Old Mar 23, 2021 | 01:10 PM
A383Wing's Avatar
A383Wing
Possible broken valve spring....did you clear the codes after swapping parts around?
Did you actually swap plugs around, or just the wires? Maybe cracked plug?
Since #3 & #4 are next to each other in the firing order, 1-3-4-2, I would swap parts with #1 cylinder to get a possible better reading from the scanner
(do not get a MSD coil pac, stay with OE....the original coil pack has been proven the best)
Bryan
Old Mar 23, 2021 | 02:51 PM
Frozer860's Avatar
Frozer860
Bryan
I did clear the code and it popped right back up. I did not move plugs. just wires. inspected the pugs when I pulled them for compression test.
I thought the MSD coil pack would be a good upgrade based on my research, it seems not though?
Old Mar 23, 2021 | 03:00 PM
A383Wing's Avatar
A383Wing
I would swap 1 & 4 plugs, see what happens. You can check spark out of the coil with a spark tester.
The mad coil is junk, stay with OE if the coil pack proves bad
Old Mar 23, 2021 | 04:00 PM
acomp182's Avatar
acomp182
Had the same exact issue with my 06. Was so relieved when I fixed it.
Old Apr 1, 2021 | 07:41 AM
Massimo Buggea's Avatar
Massimo Buggea
I had the same issue last summer, I ended up changed the plugs, coil pack and wires and the problem was gone.
Best of luck.
Old Apr 14, 2021 | 08:28 PM
Frozer860's Avatar
Frozer860
Thanks all for the help. It was indeed a bad coil. Swapped that, spark plugs, wires, and put on a 15% for good measure. Runs great but still can't clear the codes....I read on another thread you gotta use a scanner such as a NT510. Can anyone attest to that? I just have a cheapo bluetooth adapter now, and it won't clear the codes.
Old Apr 15, 2021 | 02:08 AM
MiNiSandpirate's Avatar
MiNiSandpirate
ive cleared most codes on an R53 except hidden ones or the airbag lights with just a scangauge 2
Old Apr 21, 2021 | 01:48 PM
Massimo Buggea
my Bluetooth does it fine.
try clearing them with igniton off
FL_blue_MINI
Nov 5, 2023 07:02 AM
Stephen Rivers
Feb 21, 2020 07:44 PM
arb63
Jan 17, 2018 05:35 PM
J Free
Sep 23, 2017 09:49 AM
ksweet00
Dec 1, 2015 08:38 AM
