R50/53 Should I replace timing chain and head gasket?
Old Mar 7, 2021 | 08:25 AM
Ngtphantom's Avatar
Ngtphantom
Hello all,
I am taking apart same of my engine.on a 2004 mcs with 110000 miles for maintenance , etc. I am taking the pulleys ( crank tensioner and idler pulley for replacement as they look stock) and may be taking Rocker arms to install another cam. ( maybe)
My question is if i am that close should i replace the head gasket if there are no signs of overheating yet? Just wondering if I should mess with it if it isn't showing signs of failing . ( at least it would allow me to look at the condition of the vaves )
Also should I replace the gaskets on the oil pump ( timing chain cover while.i am at it. ( if it isn't leaking should I touch it or just let it be.( I will be checking the chain guides when pulling the cam) just wondering if they are in descent shape and cover not leaking should I touch it?
Thanks for your time
Old Mar 7, 2021 | 10:30 AM
FakeName's Avatar
FakeName
It's my opinion that if it ain't broke, don't fix it. There are exceptions- damper pulley, idler pulley, etc. But I wouldn't replace a head gasket as a routine maintenance item.
And I wouldn't replace a camshaft without a whole lotta other work.
Ej Spaziani
May 13, 2020 01:40 PM
Menic
11
Jan 25, 2020 09:07 AM
AoxoMoxoA
Nov 4, 2015 06:32 AM
MiniMacster
11
Aug 8, 2013 07:05 PM
deuce40
Feb 2, 2012 02:32 PM
