R50/53 Head and timing question
Old May 11, 2020 | 06:10 PM
Ej Spaziani's Avatar
Ej Spaziani
What’s up guys long time follower first time poster. I have a 03 cooper s. Melted a piston, removed the head and cleaned all the components up! In doing so I washed off my mark off the cam sprocket, now I’m lost at how to put everything at top dead center. It has a craven 2% crank pulley with no timing marks to line up with block, I have read lots of things about the different colored links in the timing chain but still I’m lost please help!!
Old May 12, 2020 | 04:20 AM
1qwkmini's Avatar
1qwkmini
Can't wash it off it is a triangle stamped into the sprocket.
Need to pull the oil pump to see the timing marks on the crank timing gear.
Once you can see all the marks the rest is easy...align the 2 links on the chain with the crank gear...the other single link with the cam mark...tighten cam bolt down...install the chain tensioner and release the tensioner spring. Put everything all back together!!!
At the end of this page you will see what you need to look for>>>
https://new.minimania.com/part/NMK96...n1-R50-R52-R53
Old May 13, 2020 | 01:37 PM
tej98's Avatar
tej98
Is there a technique for releasing the chain tensioner from service mode after you have installed it? I tried while changing my chain guides but could not get it to pop with a screw driver. Ended up just putting it all back together and starting the car to get it to pop.
Old May 13, 2020 | 01:40 PM
1qwkmini's Avatar
1qwkmini
It's like a touch latch on a cabinet...just compress it (and the chain guide) towards the tensioner and let it go..it should just fully extend at that point.
cpmetz
Mar 14, 2019 12:06 AM
silence2-38554
Feb 22, 2016 07:08 AM
MiniMacster
11
Aug 8, 2013 07:05 PM
Porthos
Dec 20, 2011 08:17 AM
plasticknives
Mar 21, 2010 09:35 AM
