F54 Coding rear fog lights for brake lights.
Ok who has coded the rear fog lights as brake lights without a fog light switch?
Do you know the coding steps and can you share?
I saw this but I saw some say it won’t work others said it did. https://www.northamericanmotoring.co...ke-lights.html
Did it using Bimmercode, worked as advertised. Later got the combo switch with fog, and added the fog lights as well.
Rear Fogs as Brake Lights: (This hasn't been checked on a car w/rear fogs working)
BDC_BODY
3065 LceLampMapping4, ED
Funktionen
MAPPING_BREMSL_2_L_OUTPUT
Switch to this
nsl_l (this is the rear fog light choice)
You need to do this for right and left. Above is for left,
For RHS just change the l to r
MAPPING_BREMSL_2_R_OUTPUT
nsl_r__________________
BDC_BODY
Funktionen
Switch to this
BDC_BODY
Funktionen
Switch to this
BDC_BODY
Funktionen
Switch to this
I have a F54 without a fog light switch and it worked for me. The only thing I couldn’t get to work is changing the blinker from 3 blinks to 5 blinks. It just wouldn’t save it and would revert back tot he 3 blinks.
I also had to go to the dealer for a recall and was worried they would undo my brake lights, but they didn’t! 👍
Did your dealer update your MINI's software as part of implementing the recall?
I just saw it as an option when I reprogrammed my rear fog light to Brake lights and thought I would try to change it. I guess that is why it didn’t work.
A previous posts shows a separate switch next to the Hansard button. Mine doesn’t have that.
I brought my 2017 in for the rear barn door recall. I’m not sure what the software may have done for the 3 or 5 blink feature.
Apparently the barn doors could open while driving. I can’t remember if it had something to do with the rear “Kick to open” option or if they would open if the key was in your pocket and engaged the button.
SmittyRN
Jun 17, 2020 10:08 AM
Interior/Exterior Rear Fog lights to Brake Lights
Mark Kurzius
Jun 30, 2008 03:37 PM
