R55 Front Sway Bar Options
Old Nov 28, 2020 | 03:21 PM
scottyb043's Avatar
scottyb043
Hey Guys,
I've pulled the subframe out from under my R55 in order to do a bunch of work over the winter. I'm mulling the idea of putting in a larger sway bar while its all apart as it has the usual 23.5mm sway bar. Looking around online there doesn't appear to be a whole lot of options or guys running a larger bar upfront.
Anyone have any suggestions?
Scotty
Old Nov 28, 2020 | 04:26 PM
cristo's Avatar
cristo
Alliance Member
What size rear sway bar are you running?
Do you have an LSD in the transmission?
What springs/shocks?
I’ve seen 21.5, 24, 25, 26 and 27
mm front
bars listed. No hollow ones.
Old Nov 28, 2020 | 04:30 PM
scottyb043's Avatar
scottyb043
Rear is a 22mm
Looking at a helical LSD. Jury is still out on which one, but the intent is to install one while the car is apart.
Suspension is an Ohlin Coilover kit. I don’t have the spring rates handy.
With a 23.5mm front bar, it’s making me wonder if it’s worth the money to replace it.
Old Nov 28, 2020 | 04:51 PM
cristo's Avatar
cristo
Alliance Member
Would only consider a thicker front
bar in combination with an LSD and
a thicker rear bar as well to avoid
increasing wheel spin when cornering
under power and increasing under steer.
Old Dec 3, 2020 | 01:13 PM
bugeye1031's Avatar
bugeye1031
Moderator
I'm considering the same thing. I need to replace my clutch and am considering an LSD and a larger front bar. I currently have a Hotchkiss hollow 25.5 rear bar and if I remember correctly my front bar is also 23.5. I would like to go with an adjustable front bar, but I've only found one so far.
https://www.ecstuning.com/b-superpro...c0045fz26~spr/
Old Dec 3, 2020 | 01:30 PM
scottyb043's Avatar
scottyb043
Agreed. Pickings are pretty slim for front options. There was significant mass difference between the aftermarket bar and the stock one I removed in the back. With a front one of nearly 24mm, I feel like a 26mm adjustable would be the minimum starting point to make this worth the $$
Old Dec 14, 2020 | 10:46 AM
bugeye1031's Avatar
bugeye1031
Moderator
That makes sense....haven't found a 26mm bar yet though.
Old Dec 14, 2020 | 12:49 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
A few options.
https://www.ecstuning.com/Mini-2012-...way_Bar/Front/
I would go with the H&R front and rear set.
Old Dec 14, 2020 | 05:26 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I run the 27mm on my personal car and have built many customer cars with the H&R 27mm so that's what I would do and you will really like the way the car will plant itself.
https://www.waymotorworks.com/h-r-fr...ybar-mini.html
E34M5
Suspension
27
Dec 2, 2020 09:24 AM
nitroracing456
14
Aug 30, 2016 06:01 PM
Indimanic
Jun 3, 2015 03:31 AM
k_h_d
Suspension
11
Sep 3, 2012 06:22 AM
drsilvermini
Suspension
Jan 3, 2008 07:31 PM
