R50/53 Windshield washer function stopped working!
Old Oct 6, 2020 | 09:20 AM
dayman's Avatar
dayman
I'm having an issue where when you pull the windshield wiper stalk toward you (to spray and wipe with fluid) only the fluid sprays, the wipers stay at the parked position. I have to manually press down on the wiper stalk to clear the fluid. It was working fine 2 days ago, now all of a sudden it quit on me.
I checked all the fuses in the driver footwell and they were all good. I suspect one of the relays in the engine bay fusebox, but I haven't tested any yet.
Note: someone smashed by the rear driver side bumper before it stopped working. Probably unrelated though/
Old Oct 7, 2020 | 07:08 AM
dayman's Avatar
dayman
Bump. Any ideas?
Old Oct 7, 2020 | 08:13 AM
ssoliman's Avatar
ssoliman
That sounds like an electrical issue...so I should probably not be responding (so bad with electrical). :/
do you have a Bentley manual?
that would lead you to the fuse and provide the electrical diagram.
also I replaced the windshield wiper control / lever just recently. Got it used here: allmagautoparts.com
found a vid on YouTube. Easy peasy... might fix your issue
Old Oct 7, 2020 | 08:38 AM
dayman's Avatar
dayman
I figured it would be something electrical, but hopefully it's not a major issue with the electrical system...
It was working perfectly fine, up until now. It's not a major thing obviously, just a little annoying to have to depress the washer stalk to wipe off fluid like a peasant. Why do it myself when the Mini does it for me.
06_Mini_Blue
Nov 27, 2012 06:39 AM
Eli_El_321
Aug 1, 2012 10:35 AM
crappie_fisherman
Nov 5, 2010 07:09 PM
Buzzbcooper
12
Sep 27, 2006 01:53 PM
