Windshield Wiper Fluid Empty?
Old Feb 14, 2012 | 08:59 PM
06_Mini_Blue's Avatar
06_Mini_Blue
Hello Everyone,
I posted not to long ago that my windshield wiper fluid empty light is flashing indicating that I need to refill the fluid, I did that and still the light is flashing and nothing is happening when I try to use the wiper sprayers. I can hear the motor trying to pump it, but nothing. I called the dealer and the mechanic said that the 2006 models have two tanks for fluid, so where is the other one? I found the one on the passenger side that goes into the fender. Can someone please help me?
Old Feb 14, 2012 | 09:00 PM
Squirlz's Avatar
Squirlz
The other one is in the same place on the drivers side. Have you found michiganmini.org yet?
Old Feb 15, 2012 | 06:57 AM
06_Mini_Blue
Thank you I will check this out when I get out of class. And I checked out michiganmini.org, very nice! I will register for that soon here. I am actually creating my own forum as well! I am in the design stage now!
Old Feb 15, 2012 | 07:13 AM
mdsbrain's Avatar
mdsbrain
Originally Posted by 06_Mini_Blue
Hello Everyone,
There is one on each side of the car one in each fender. The passenger side I believe is only for the Headlight washers.
Old Feb 15, 2012 | 07:55 AM
Braminator's Avatar
Braminator
Divers side tank is for headlights and passenger side for windshield.
Old Feb 20, 2012 | 05:52 AM
zamfield's Avatar
zamfield
I did the sme thing... Had the mini two days and needed to fill up due to the flasher.
Thought I'd filled it up - bit realizing there's two bottles to fill... Headlight & windshield, one either side! LOL!
Old Feb 20, 2012 | 09:05 AM
dannyhavok's Avatar
dannyhavok
The caps have pictures of a headlight and a windshield, respectively, in case you forget which is which.
Old Feb 20, 2012 | 09:08 AM
alwzopn's Avatar
alwzopn
This is also in the manual.
Old Feb 24, 2012 | 07:34 AM
06_Mini_Blue
I still have not figured out the issue. I can not find another tank either.. My car did not come with a manual :/
Old Feb 24, 2012 | 07:39 AM
Spooled's Avatar
Spooled
If your car doesn't have headlight washers, you probably won't have the second tank. You may have a faulty sensor in the passenger side tank. I do find it odd, however, that the tank is full and you can hear the motor running, but no fluid sprays onto the windshield....
Old Feb 24, 2012 | 07:59 AM
Capt_bj's Avatar
Capt_bj
2006 owner's manual
http://www.minimania.com/pdfile/2006_MINI.pdf
Old Feb 24, 2012 | 10:12 AM
zamfield's Avatar
zamfield
Ho about getting a pic of the engine bay, showing the sides too... that way we can check if you have one or two filler spouts.
Also, have you filled the fluid up to the marker... to the top?
Hello Everyone,
Old Feb 24, 2012 | 08:21 PM
ZippyNH's Avatar
ZippyNH
Had your car for 2 years and about 30,000 miles according to you signature....
And haven't had to add washerfluid?!
if equipped, second filler is the same spot on oposite fender.
Old Mar 5, 2012 | 07:23 AM
06_Mini_Blue
Thats the thing. I have added fluid and it worked find up until now... :/ I am at the dealership right now getting the oil changed at the Mini dealer. There is only one tank they said and I am not going to have them look at it right now because they are going to charge me $80 just to tell me what is wrong with it. Even if the sensor was bad wouldn't it still push fluid to the nozzles? UGH this is so frustrating! Neither the front or rear is spraying.
Can anyone think of anything else I can try? I will post pictures later on after I leave "The Sharpe Collection" dealership in Grand Rapids, MI.
Thank you everyone for your support and thoughts so far!
Old Mar 5, 2012 | 07:31 AM
06_Mini_Blue
Alright so the dealership just me that the fluid tank is cracked!!! How in the heck does that happen! Well at least I know what it is now... Thanks everyone!
Old Mar 6, 2012 | 02:37 AM
ZippyNH's Avatar
ZippyNH
Based upon the time of year, it sounds like the tank had some summer fluid in it...froze, and cracked....
Old Mar 29, 2012 | 08:01 PM
06_Mini_Blue
Anyone know of a good place to get a replacement that isn't to steep in price?
Old Mar 29, 2012 | 09:40 PM
ZippyNH's Avatar
ZippyNH
If you are gonna diy it, you can get a used one from someone parting out a car...waymotorworks does this with wrecks sometimes....so often it is a goodway to get some parts cheaper than the dealer...he can get new too cheaper than dealer prices too.
Old Mar 29, 2012 | 10:56 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
I will have one up for sale as soon as I pull the A-panels off. Probably about a month from now.
The pumps also like to leak (Atleast on the 2 MINIs Ive had) the tank will drain itself all because of a stupid O-ring.
Old Mar 30, 2012 | 07:28 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Most of the time they are just filled with water, freeze and crack.
I may have a used one off a wreck, call the shop on Monday and we'll see if we got one for you.
Old Nov 27, 2012 | 06:39 AM
inthefad3's Avatar
inthefad3
I have a somewhat opposite problem. While the empty light does not turn on and I just added winter version of wiper fluid, no fluid comes out. I too have only one tank since my Mini does not have headlight wipers. I thought that I may have a leak but I have not noticed any leaking.
Does anyone know what else could be causing the problem?
patsum
26
May 29, 2021 06:29 PM
Hobine
Oct 7, 2015 04:52 PM
nomar116
Electrical
Sep 20, 2015 10:26 AM
bobbi.steines
Sep 10, 2015 11:31 AM
