R50/53 Help! Dsc & tpms light on | Lithium battery
Old Sep 27, 2020 | 03:14 PM
Serafin's Avatar
Serafin
hello fellow Miniacs. So the car was running perfect. Before the corona hibernation. No codes. New tune. Everything is on point. Decided to park the car for 3 months or so.
During the hibernation I’ve been modding the exterior only. Been on jack stands on and off.
Added new gauges as well.
Then i decided to upgrade the battery to a 2.5lbs lithium battery. So Tiny. Needed to find room for my meth install. Anyways. Car started. But now The DSC and the TPMS lights are on. I can’t turn it off from the toggle. I tried resetting the TPMS, That didn’t work either.
Took her out for a spin. Did couple pulls here and there and the traction control is off. Wanted to make sure it’s not just a malfunction light.
i don’t mind the DSC because i mostly have that off anyway unless it’s raining.
Anyone here has that experience? There’s no codes when i plug my OBD scanner.
is it a bad TPMS sensor? TPMS sensor works with DSC ?
Thank You in advance.
my homemade batte tu holder. Still have to finish it. Got an aluminum one in the making.
Old Sep 27, 2020 | 04:49 PM
colinmini's Avatar
colinmini
Simple test
just swap the old battery back in and see if codes stay.
Old Sep 27, 2020 | 05:01 PM
Serafin's Avatar
Serafin
it’s dead lol. Don’t know if it dries something from swap maybe? I’ll swap it and put a jumper on it.
Old Sep 29, 2020 | 01:32 PM
Serafin's Avatar
Serafin
Swap
update-
swapped the battery with the old one. Both light still on. 🤷🏻‍♂️
Old Sep 29, 2020 | 02:31 PM
MINIAC's Avatar
MINIAC
The cause of the DSC & TPMS lights staying on in my 2002 MCS was a bad steering angle sensor.
Old Sep 29, 2020 | 03:40 PM
Serafin's Avatar
Serafin
thanks.
how did you find this? Did you get a code?
Old Sep 29, 2020 | 03:43 PM
Serafin's Avatar
Serafin
also. How did you calibrate it after replacement ? Thank You
Old Sep 29, 2020 | 04:04 PM
MINIAC's Avatar
MINIAC
Originally Posted by Serafin
thanks.
Sorry I can't answer your questions. This happened while my car was still under warranty and the dealer took care of it.
Old Sep 29, 2020 | 04:15 PM
lotter1's Avatar
lotter1
I also had those two lights. Did the steering angle sensor cleaning and calibration and that did not fix it.
I also checked the sensors on the wheels and also not the culprit.
I then read somewhere that it might be the RPM cluster. Bought a used one from WMW and that fixed my lights.
Old Sep 29, 2020 | 05:29 PM
Serafin's Avatar
Serafin
oh my goodness. so weird why would it be the rpm cluster.
i have the Double unit with The Nav.
i found this regarding the steering angle sensor. Will give this a try and see. https://www.mini2.com/threads/dsc-ru...-sensor.45536/
Old Oct 4, 2020 | 06:03 AM
Serafin's Avatar
Serafin
MINIAC & Lotter1 was right. I used a foxwell scanner. Scanned the SAS and it was faulty.
cleared the DTC and both lights came off. Let’s see if it comes back.
i suspect the problem happened then the battery went dead as i was jacking the car up and down maybe while turning the ignition on 🤷🏻‍♂️
Old Jul 22, 2022 | 03:39 AM
mdurando's Avatar
mdurando
Serafin: Did just clearing the DTC permanently fix your issue with the TMPS and DSC? Or did you end up replacing the SAS?
Old Jul 23, 2022 | 06:45 AM
Serafin's Avatar
Serafin
clearing it fixed it. Haven’t seen it come back.
Only light that’s bugging me now is the airbag light lol
i forgot to plug it back in when installed my seats. Now it’s always on
arkdangel
Tires, Wheels, & Brakes
12
Apr 27, 2015 06:02 AM
FunkyMunkey
Aug 28, 2014 11:08 AM
AMink
Sep 2, 2012 08:15 AM
d@g
Jan 16, 2012 08:32 AM
Newdl
Mar 25, 2006 07:50 PM
