R56 Anyway to access TPMS readings directly (NCS Expert perhaps?)
Old Jan 16, 2012 | 06:15 AM
d@g's Avatar
d@g
Just curious if there's a way to read the actual pressures being measured by the wheel sensors using NCS Expert or something along those lines. I know there are wireless scan tools designed for this purpose, but they are pricey. Just trying to troubleshoot a TPMS problem on a Gen2 MINI. Thanks.
Old Jan 16, 2012 | 08:21 AM
strobeyprobey's Avatar
strobeyprobey
Yep! DIS has each wheel's pressure, signal strength, and battery life listed!
I can't remember if INPA worked for me on the TPMS, so many modules don't work right with INPA.
Old Jan 16, 2012 | 08:28 AM
d@g's Avatar
d@g
Ah...I half expected I'd need DIS. Still haven't found time to get that up and running yet. You need to set up virtual machine on the laptop if I recall. I hadn't even thought about the TPMS sensor battery -- any idea if, when they die, they send a separate warning or what their lifespan is?
I'm due for service next month (last while under factory warranty), so I might just have the dealer fuss with it then, but it would be interesting to get the actual pressures.
Old Jan 16, 2012 | 08:32 AM
strobeyprobey
Yep needs the VM, it is not the easiest to get running, but pretty easy to use once it is all setup.
Yeah I believe the dash warning will be TPMS malfunction instead of a LOW TIRE warning. But it doesn't specifically say low battery.
Battery life is claimed to be about five years.
barnoun
Sep 17, 2018 05:04 PM
R56BrgMcs
Oct 6, 2015 07:10 PM
Witsticka
Sep 15, 2015 01:33 PM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
skippermini
Aug 13, 2015 06:13 AM
