R50/53 Coolant Hose Question
Old Sep 14, 2020 | 08:40 AM
redrockpdx's Avatar
redrockpdx
My 2006 R53 w/ Automatic and has a coolant hose failing that comes off the backside of the hard water pipe and connects to a T-Splitter. Based on my research I have two options 1) purchase a new 8-way hose P/N: 17127541095 as it is not sold individually or 2) a DIY solution that replaces the failing section of the heater hose or 3) P/N: 17127518574 #24 in below chart lists this on realOEM but for M/T does not specifically call for A/T - don't know if same part
The hard part is that this hose piece is a reducing 90-degree fitting. Before removing the hose and measuring myself I was hoping someone might have O/D of the hard water pipe and the O/D of the T-splitter (shown in image) to size the hose right.
One company I found does sell reducing elbows so there is some hope that doesn't run $110+ for one hose: https://www.pegasusautoracing.com/ke...ywordButton=Go
Thank you!
O/D of pipe on the hard water pipe needed
#6 shows the hose that is failing (#6 is a hose clamp part number)
#24 might be the part but not listed for A/T
Old Sep 14, 2020 | 02:55 PM
Mini Devil's Avatar
Mini Devil
On a MT it's a 5/8x3/4 reducer. There isn't a 90° bend in it though. Replaced mine with the same brand your considering.
Old Sep 14, 2020 | 05:27 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
if you had it off alot of times at your local parts stores they stock alot of random sizes and bends of coolant hoses n stuff in the back..alot of times they will even let you go look for it your self. Might be worth trying.
Old Sep 17, 2020 | 01:32 PM
redrockpdx's Avatar
redrockpdx
Thanks guys for suggestions.
Found this hose that is a 90° sweep of 5/8 to 3/4 I.D. Just needs some trimming. If doesn’t work then off to parts store to find a heater tube
htroberts
Aug 3, 2019 01:24 PM
Lex2008
Jan 22, 2019 05:12 AM
KrisMiss
Jan 3, 2016 02:02 PM
fourblades
Oct 8, 2013 09:44 PM
NC TRACKRAT
Jul 8, 2012 04:03 AM
