Navigation & Audio 05 November stock radio, what aux will work?
Old Sep 10, 2020 | 04:18 PM
AndrewVanis's Avatar
AndrewVanis
$8 AUX that works (SOLVED) - 05 November stock radio, what aux will work?
Edit update
Amazon Amazon
this $8 solution works. the BT one mentioned did not work.
End edit
2002 R53. Got this newer 05 radio. The aux BT thing I got for BMW maybe would have worked if the BT would have connected thus so far no verified AUX.
What is a AUX connection that should work with this?
Old Sep 10, 2020 | 05:19 PM
RB-MINI's Avatar
RB-MINI
The safest would be the factory aux accessory jack which is around $35, but many have used $10-$15 one’s from Amazon or eBay with success. If your car is wired for a cd changer or you have NAV, you’ll probably need to transfer the aux wires from its connector to the connector already plugged into your radio. This is shown in the factory instructions high can be found online.
Not sure when using a factory aux, but a ground loop isolator might be needed if you have any noise or whine with an aftermarket adapter.
What BT unit did you get and are you using it only for music, or calls too?
Old Sep 10, 2020 | 05:36 PM
AndrewVanis
Does anyone have an aftermarket one they have used successfully?
this is the BT unit
https://www.ebay.com/itm/12Pin-Bluet...72.m2749.l2649
The pairing did not work. The seler was responsive but the instructions provided did not work. They refunded my $ and didn't ask for it back so may goof around it some more.
Old Sep 10, 2020 | 06:02 PM
RB-MINI's Avatar
RB-MINI
The pairing between the phone and unit isn’t happening, or you see the connection on the phone, but no sound is coming out of the radio? That s the first I’ve seen in a small combo unit like that. Most use add aux 3.5mm jack, then plug a BT module or cable into it.
Old Sep 10, 2020 | 06:06 PM
AndrewVanis
unit to phone...that pairing did not work. phone saw unit briefly then unit disappeared.. if I happened to catch it it hung up and eventually said it couldn't connect. also, the unit name was different than what the seller said it shoudl be.
Old Sep 10, 2020 | 06:27 PM
RB-MINI's Avatar
RB-MINI
Sounds like a poorly designed unit, but at least you got a refund for it. Here’s a recent link on BT with a 1st gen MINI: https://www.northamericanmotoring.co...t-adapter.html
Almost all of the posts I remember reading use a wired aux port from the radio with a BT unit connected. For a compact hidden setup I’ve been thinking of a wired aux and USB port in the glovebox with Tunai firefly BT adapter.
Old Sep 10, 2020 | 07:36 PM
AndrewVanis
I've ordered these two try try (thx Amazon free returns
Amazon Amazon
Amazon Amazon
And would like this one as it has microphone though no free returns and long shipping
https://www.ebay.com/itm/Car-Audio-W....c100005.m1851
Old Sep 12, 2020 | 07:47 PM
RB-MINI's Avatar
RB-MINI
The Amazon BT module linked above looks like similar version of your defective eBay module. To use either one, you won’t need the wired 3.5mm aux jack in the first link above. With either the aux jack or those BT modules, the wires that go into the back of the radio might need to be transferred to the existing plug in your car depending on it's options.
Old Sep 17, 2020 | 08:37 PM
AndrewVanis
the cord worked. the BT did not.
they were wired differently and plugged into to different section of the connector. would have loved to have BT directly but fo $8 I'm happy enough fo rnow.
knotcher
Dec 13, 2010 08:23 AM
vargasgal
Mar 20, 2009 07:26 PM
nthwolf
Sep 14, 2008 12:34 AM
ripley
Sep 24, 2005 05:41 PM
