R56 Fuel Codes after Thermostat Replacement
Old Sep 9, 2020 | 11:30 AM
Errant's Avatar
Errant
I could use some help!
I just did a bunch of work on my ‘09 MCS... oil cooler seals, filter housing seals, coolant pipe and thermostat housing. All looked and ran good until I sprung a leak at the coolant pipe to thermostat junction. So I tore it apart again to find that o-ring had deformed when I put them together. I replaced it, all seems good, but now I’m throwing fuel codes P0001, P0300, P0301, P0304.
Any ideas as what I screwed up this time around? Did I not get something plugged back in correctly? It seems the only two connectors that can be mixed up are the one for coolant temp on the top of the thermostat (two wires, yellow and white) and the one for the crankcase breather element (two wires, orange and black). I do have those correct, yeah?
I kind of want to cry at the thought of pulling it all apart for the third time, and am really hoping some of you will be able to tell me I should be looking for.
Thanks a bunch,
Kristina
Old Sep 9, 2020 | 11:57 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
My guess is you did not get the fuel pump connector plugged in correctly
P001 is a general fault for fuel control. The other P03xx are misfire codes.
Old Sep 9, 2020 | 01:46 PM
Errant's Avatar
Errant
Thanks for replying, I do appreciate it! This is the only one, yeah?
Old Sep 9, 2020 | 01:49 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
That's the connector I was thinking of!
Old Sep 9, 2020 | 02:06 PM
Errant's Avatar
Errant
I just unplugged it and put it back, it seemed OK. Anything else to look at before I put the intake and air box back? I feel like I’ve been staring at everything so much that I’m not really seeing any more, if that makes sense.
Old Sep 9, 2020 | 02:38 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Based on your codes, I can't think there would be anything else...
Old Sep 9, 2020 | 03:27 PM
Errant's Avatar
Errant
This is so frustrating :( I’m going to take a nap and put it back together later. Sometimes things magically fix themselves after a nap.
Old Sep 9, 2020 | 06:03 PM
Errant's Avatar
Errant
Woot! The nap worked! Or, it was your suggestion to double-check the HPFP connection. Thank you 🙏
Old Sep 9, 2020 | 06:26 PM
Errant's Avatar
Errant
Going to take it for a spin and see if I spring any leaks or throw more codes. Cross your fingers 🤣
Old Sep 9, 2020 | 06:46 PM
Errant's Avatar
Errant
Or not, now my bonnet won’t catch LOL
And yes all tools are accounted for. Oops minus one tiny extendable magnet thing.
Old Sep 10, 2020 | 02:57 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
otterby
Jun 2, 2020 09:42 AM
sani
May 13, 2020 07:55 AM
gnarmach
Sep 4, 2019 06:28 PM
Sayeed
Jul 5, 2017 11:32 AM
Solute
Jun 24, 2015 08:17 AM
