R50/53 Supercharger life ?
Old Sep 8, 2020 | 02:02 PM
alconk's Avatar
alconk
Supercharger life ?
I just read that the supercharger life expectancy is only 100k miles. Other than the bearings what else dies in these? I have 158k miles and still gets 16-18 psi of boost. At 133k I changed the oil on both ends although one end was empty. Do the rotors ware?
Old Sep 8, 2020 | 03:01 PM
Mini Devil's Avatar
Mini Devil
I feel as though your on borrowed time. If the back end was empty, that indicates the rear seal has failed. Its actively siphoning oil from the back into the case.
​​​​The rotors don't wear to my knowledge, but I could see them getting out of spec if there is too much play in the snout. There is however a few bearings that can wear out. I don't know exactly how many seals there are. Also the nylon coupler in the front is replaceable.
Old Sep 9, 2020 | 12:44 AM
alconk's Avatar
alconk
Ok thanks! Can you recommend a rebuilder. Mine has the newer black rotors.
Old Sep 9, 2020 | 07:09 AM
SupeR53's Avatar
SupeR53
I've got 175k on my original SC, I had the oil changed at 140k when the single mass flywheel and clutch went in, and still have great boost. The biggest key to these is routine maintenance, once the seals start to leak, its just a matter of time IMHO. As an aside, I do have a new JCW SC put away for when the original DOES go out (bought it on closeout 2 years ago).
Old Sep 9, 2020 | 07:50 AM
steve05ram360's Avatar
steve05ram360
besides the pulley, whats the difference from an MCS version of the supercharger?
Old Sep 9, 2020 | 09:39 AM
alconk's Avatar
alconk
Nice! Lucky you
Old Sep 9, 2020 | 09:50 AM
mountainhorse's Avatar
mountainhorse
Good info here.
http://thehighspeedlab.com/mini-coop...rchargers.html
Many are in great shape with lots of miles... and just need good service... Replace water pump while you are at it from the info I've gleaned
Old Sep 9, 2020 | 11:10 AM
cooper48's Avatar
cooper48
JCW version is the same supercharger but has an 11% pulley.
Old Sep 9, 2020 | 12:02 PM
mountainhorse
And coated rotors as well, I believe...
Old Sep 9, 2020 | 12:23 PM
RB-MINI's Avatar
RB-MINI
Pre-facelift - the coating on the rotors
Post - no difference
Old Sep 9, 2020 | 07:14 PM
Mini Devil's Avatar
Mini Devil
This guy is well trusted in the ford lightning community. With better (and consistent) results then other builders. Rebuilt and ported many m112 blowers. He offered a front end only rebuild on mine for a sweet deal. I deleted the PTO driven pump, and went electric. Also if you get it ported, they rebuild it for free(bearings, oil, seals)
https://jokerzperformance.com/
Old Sep 9, 2020 | 09:05 PM
ghostwrench's Avatar
ghostwrench
Does anyone have personal experience with Jokerz, High Speed Lab or another S/C rebuilder?
My car has nearly 158k miles and there is a rattling noise in the engine compartment. I haven't put a stethoscope in the engine compartment yet but the sound seems to be beneath the intercooler vs at the front of the engine (timing chain area). I've owned this car since new and done all post warranty service work on it myself (except for the power steering pump done under recall at the dealer) so I know the supercharger has never been serviced.
FCPEuro lists a Mini supercharger for $1371 which comes with a lifetime warranty. The High Speed Lab lists supercharger rebuild with PTO remanufacture for $1045 and Jokerz doesn't specifically mention the Eaton M45 in the R53.
My car is a daily driver and I would prefer to do this replacement in one day and dealing with a core vs pull my S/C, send it somewhere and wait for the rebuild. I know FCPEuro charges a core but what about the other two?
Old Sep 10, 2020 | 05:18 AM
Mini Devil's Avatar
Mini Devil
I had the same rattling sounds. Probably the backside of the SC. Mine was in pretty bad shape. It was cheaper for me to delete the PTO. Rebuilding the SC was more costly, when also factoring the WP. You can check out my build thread if your interested.
I've had experience with Jokers working on my Lightning in the past. It's why I called him about my MINI. He said "If it's an Eaton, I can rebuild it". He's a really cool guy. I've read countless testimonials over on the lightingrodder.com forums, been there over a decade. Back when Steig and Joker were trying to outdo each other. Before Steig had to sell off the company. I won't go into the details of why.
You'll have to call about pricing. I haven't been to the website much. I've only dealt with the owner on the phone, or in the forums. He's a site vendor. Tell him a lightning rodder member sent you over from the MINI forum. It'll blow his mind lol
Ketchup
Mar 16, 2018 08:59 AM
hexproject
Oct 6, 2015 01:57 PM
BlackJCW
Sep 3, 2007 01:14 PM
greatgro
Sep 6, 2005 03:49 AM
mountainrider
Apr 15, 2004 06:55 PM
