R56 Gfb dv+ p115c???
Old Aug 10, 2020 | 12:36 PM
Way2Fst4U's Avatar
Way2Fst4U
Gfb dv+ p115c???
Just installed a GFB DV+ and everything was fine until I decided to jump on it a bit and check the boost... Instant P115C and limp mode (no turbo). Anyone else experience this or is it just a coincidence and something else causing this error? I can reset the code and if I baby it...all is good. As soon as I get to 10-12psi the code hits again.
Thanks in advance for any assistance.
Old Aug 10, 2020 | 12:40 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Any other MINI specific codes being stored?
Have you tried running with out the larger main spring?
https://gfb.com.au/wp-content/upload...structions.pdf
Old Aug 10, 2020 | 12:51 PM
Way2Fst4U's Avatar
Way2Fst4U
It's too hot right now...I figured I'd post while I wait for it to cool down. Yeah I'm going to pull the big spring off the top piston and see if that helps. Thanks!
Old Aug 10, 2020 | 01:01 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I'm mostly curious if there are any other MINI codes stored for the fault. P115C is a general OBD code. With the CAN bus system on the MINI there should be other codes to help clue you in to the details, but you need a BMW/Mini code reader to get them out.
Old Aug 10, 2020 | 01:02 PM
Way2Fst4U's Avatar
Way2Fst4U
Probably my bad for clearing them all out days ago...but nothing else popping up.
Old Aug 10, 2020 | 01:18 PM
Way2Fst4U's Avatar
Way2Fst4U
Basically just wondering is this is the CEL people get when they complain about the DV+ or if I should just go back to the stock diverter?
Old Aug 10, 2020 | 01:50 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I should have searched first...
See here:
https://www.northamericanmotoring.co...-solution.html
Maybe your full throttle romp pushed a boost tube loose.
Old Aug 15, 2020 | 05:57 PM
Dfly1972's Avatar
Dfly1972
I just installed this a few weeks ago. no issues. I'm stock tho. with a very heavy foot. lol. I have the recirculating version.
drumband
Dec 3, 2018 09:59 AM
uni
Aug 20, 2018 07:24 AM
SpuuDy
Nov 24, 2016 04:01 PM
MCS9211
Feb 12, 2016 07:36 AM
Yeah.ThatsRice.
Sep 23, 2010 08:33 PM
