R50/53 Passenger side axle
Old Jul 25, 2020 | 12:27 PM
ijourneaux's Avatar
ijourneaux
Passenger side axle
I finally have all of the parts I need to replace the struts, and links on my Coop. Everything was going well until I lost the support under the steering knuckle. it droped a couple of inches but enough to pull the axle apart. The boot is still on the axle but the axle is disconnected inside of the boot. Is it just a matter of trying to figur eout how to slip it back into place? Can I do this without taking the boot off? Any tips appreciated. THis is normally an easy job but it has been anything but today. Take Care all.
Ian
Old Jul 25, 2020 | 01:24 PM
ssoliman's Avatar
ssoliman
If the boot is not ripped you should be good.
why do you say it’s not going back in?
when you turn the hub does the whole axle turn also all the way back to the trans?
Old Jul 25, 2020 | 01:46 PM
ijourneaux's Avatar
ijourneaux
Boot isn't ripped but it is definitely disconnected.Turning the hub only turns to the boot. RIght now the axle is still attached to the hub. Probably going to have to get it out of the hub to have any change of getting it back together.
Old Jul 25, 2020 | 04:23 PM
ijourneaux's Avatar
ijourneaux
How to confirm that CV went back together correctly?
Took a break and switched the the drivers side. It went the way it should have gone. Back on the passenger side with the knuckle supported by the struct, I was able to get the CV joint on the axle to slide together again. I have no idea how a CV joint works so is sliding it together good enough or do I need to slide the boot off and confirm that the bearing are where they should be.
Hopefully tomorrow I can go out double check the torques everywhere and schedule an alignment for Monday!
Old Jul 25, 2020 | 09:04 PM
ssoliman's Avatar
ssoliman
Looks like the shaft goes into the joint with splines...the shaft probably just came out.
is the hub turning the entire shaft now?
id put it back together and test by hand then on a slow drive. Very slow at first
[img]blob:https://www.northamericanmotoring.com/dc176471-f26c-4b8d-982d-84fa21893696[/img]
Old Jul 25, 2020 | 09:08 PM
ssoliman's Avatar
ssoliman
The suspension geometry makes it so the shaft has no place to go...
Old Jul 25, 2020 | 09:35 PM
ijourneaux's Avatar
ijourneaux
Thanks for the picture. Does explain seem to explain how it works,. Once I got it slipped back in the everything turns all of the way to the other side. Also with it slipped out, I couldn't get the steering knuckle to lined up with the lower ball joint. I got everything back togehter and will take it very slow tomorrow. If the design is like the picture, it is hard to see how it could go back in wrong. When it first happened, the web search brought up a design where that was not the case.
Old Jul 26, 2020 | 01:01 PM
ssoliman's Avatar
ssoliman
Yes sir. Also found this:
Old Jul 26, 2020 | 04:40 PM
ijourneaux's Avatar
ijourneaux
Car is reaseembled will be getting an alignment Mon or Tues
bergie33
Sep 22, 2018 07:44 AM
charleshughk@gmail.com
May 20, 2016 07:35 PM
chicohuahua
Apr 15, 2015 08:07 AM
flatblackmini
Apr 26, 2012 05:15 AM
SooperCuperErik
Feb 22, 2012 06:01 AM
