2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Harmon Kardon under seat speakers
Old Jul 24, 2020 | 03:42 AM
KindaCoolDad's Avatar
KindaCoolDad
I just picked up a 2017 Countryman All4 S today. Fantastic fun so far, but I’m worried about the under seat speakers. I have a Harmon Kardon system but it doesn’t feel or sound like they’re producing anything at all. Do they serve as subwoofers? Because if so they have nothing going on for me right now.
Any ideas?
Old Jul 25, 2020 | 11:49 AM
tsaylor's Avatar
tsaylor
Yes. As subwoofers go they are not impressive but you should definitely be hearing something. Have you already tried turning up the bass setting on the infotainment menus?
Old Jul 26, 2020 | 12:34 AM
KindaCoolDad
I think it may be an amp issue. I have to turn the bass to about 90% to hear any bass from the door speakers, but still nothing from the underseats. I also have to turn the overall volume at least 50% or higher for the audio to be at a decent level.
Old Jul 26, 2020 | 09:52 AM
d2mini's Avatar
d2mini
Can't really answer your subwoofer question. You shouldn't be able to tell where bass is coming from but I never put my ears under the seat to check. If I didn't happen to know there were speakers under there, I never would have known just by listening. The HK will not give you big boomy bass.
Your description of the volume sounds about right. Mine is usually over the 50% mark if I'm driving alone.
Old Jul 26, 2020 | 10:02 AM
KindaCoolDad
I took the grills off and put my hands on the speaker at max bass and 75% volume - absolutely nothing coming from the under seat speakers. I have an appointment with the dealer in a couple weeks to check it.
Old Jul 26, 2020 | 07:22 PM
madmix's Avatar
madmix
So could be lots of things. The are subwoofers by definition in a three way system, They produce the lower range of the full range signal. The AMP has the lowpass filter that send the lower freq to the subwoofer and then send full range to the mids. the mids they high pass to the tweeters. I would suggest to ensure the subs are hooked up. Should be a single plug from the amp. If they are hooked up and still not working, take a look at your amp, there are lots of things going on in between. Here is a wiring diagram that should help you troubleshoot
https://www.newtis.info/tisv2/a/en/f...ers/1VnXpLKQEQ
Old Aug 17, 2021 | 11:20 AM
Mand0o's Avatar
Mand0o
Just to chime in, I have the HK system in my 2018 CM S and I also don't feel/hear anything from the under seat speaker. Most of the bass I hear sound to be coming from the doors.
OP, did you ever get the dealer to check out the issue?
Old Aug 24, 2021 | 03:29 AM
mattyb13's Avatar
mattyb13
I have a 2019 ALL4-S Countryman and my $.02 is that the HK system in my car delivers quality sound but is very weak overall from an output perspective. I had a 2016 CM All4-S, and the HK stereo in that car was much stronger, louder, and delivered more bass. I have never been a fan of the stereo system in my 2019.
Old Aug 24, 2021 | 06:34 AM
tom992's Avatar
tom992
Check this too:
https://www.bimmer-tech.net/blog/ite...r-sound-system
https://www.bavsound.com/
hotknife
Sep 9, 2015 10:45 AM
rennwerkes
Jun 18, 2013 07:27 PM
reducati
Chicago MINI Motoring Club
May 18, 2012 04:38 PM
rsosborn
Aug 31, 2011 05:02 PM
fixman2k
Mar 17, 2010 11:52 AM
