R56 Bc coilover install question
Old Jul 19, 2020 | 09:57 PM
Dfly1972's Avatar
Dfly1972
I installed a set of bc coil overs today. The rears came with extensions so I can remote locate the adjustment dial. Has anyone installed these? How and where?
TIA
Old Jul 20, 2020 | 12:36 AM
al the mini man's Avatar
al the mini man
To fit the remote adjusters you have to drill a hole in the wheel arch,this is in line with the top of the shock so that you have a hole that comes out in the boot area then you can fit the adjuster to the top of the shocker and thread it through into the boot.Hope this makes sense.
Old Jul 20, 2020 | 08:46 AM
Dfly1972's Avatar
Dfly1972
ok. I understand drill a hole right above the shock. You lose me at boot. Lol. Is that in the trunk? Or still on the outside of the car?
thanks!
Old Jul 20, 2020 | 09:13 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Boot = Trunk
Be careful, there are wire harnesses above the rear shock mounts. If you're not careful, you'll drill right into them.
https://www.northamericanmotoring.co...ml#post3657751
Old Jul 20, 2020 | 01:58 PM
Dfly1972's Avatar
Dfly1972
Originally Posted by njaremka
Boot = Trunk
got it. Thanks!
Old Jul 21, 2020 | 12:44 AM
al the mini man
Sorry i forgot you call the boot a trunk over there also as Njaremka says be careful of the wiring.
Old Jul 22, 2020 | 05:39 PM
Dfly1972's Avatar
Dfly1972
Thanks for the help. Panels out. I have a few metal plates I’ll use to protect the harnesses, that are directly in the line of fire. Lol. Tomorrow after work job.
97nicolaus
R61 :: Paceman Talk
Feb 4, 2017 01:09 PM
Mini_Touge
Suspension
Dec 3, 2015 11:45 AM
Max7
Suspension
11
May 4, 2013 01:23 PM
goin440
Suspension
21
Aug 7, 2009 07:00 AM
MiniJayhawk
Suspension
Dec 5, 2007 02:06 PM
