Suspension MachV Spring install question
Did a little search and didn't find a distinct answer, but:
If I install the Mach V springs on the stock Mini sport suspension, will I need to align the car? Does the drop change the toe readings on the front/rear?
Thanks!
Thanks!
toe was off a little on the back wheels and a lot on the front, enough that I would have definitely had uneven tire wear. I'm glad I took it for an alignment!
melscoop
Mar 30, 2016 06:56 PM
squawSkiBum
Oct 2, 2015 09:21 AM
Nevermind. I just found Dan's recommendation to "always check alignment." But it that a CYA statement, or have people found an actual change to the toe readings?
