R50/53 Strange missfire/bucking issue? Ideas?
Old Jul 8, 2020 | 10:59 AM
IQRaceworks's Avatar
IQRaceworks
My 03' R53 started doing some weird stuff on the way home from work yesterday. When ever I start getting on the gas, and I start building boost.....the power from the motor will cut out for a second, almost feeling like a misfire or dead cylinder. It didn't do it every time I got on the gas, but most of the time it would....it would bobble and skip a beat or too. The plugs and wires aren't that old...but it sure does feel like some sort of misfire.
I don't have any codes ...so I'm at a loss. Should I just go ahead and change the plugs and wires, or could it be something else?
Old Jul 8, 2020 | 12:19 PM
ssoliman's Avatar
ssoliman
Could be the bypass valve
if you go on full throttle straight away do you get any hesitations?
Old Jul 8, 2020 | 12:23 PM
IQRaceworks
If it was the bpv....I would think that I would lose boost, and I'm not. It's maintaining boost when it does the missfire/bobble.
Old Jul 8, 2020 | 12:56 PM
Canyon_Mini's Avatar
Canyon_Mini
Replace the front map sensor.
Old Jul 8, 2020 | 01:31 PM
Soul Coughing's Avatar
Soul Coughing
I had an issue with a misfire under load; actually twice, and changing out the coil fixed it. If you have an extra coil, just swap it around and see if that helps.
Old Jul 8, 2020 | 07:57 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
I was going to say this too. Check the terminals for corrosion too possibly .
Old Jul 8, 2020 | 08:08 PM
tej98's Avatar
tej98
I have a misfire/hesistation under heavy load as well. Went to swap the coil out today and 2 of the 4 bolts were stripped (on the valve cover side) so take it easy when removing and tightening the coil pack bolts.
Old Jul 9, 2020 | 05:10 AM
IQRaceworks
Yes.....it feels like a misfire. I will take a look at the coil. If it's got a lot of corrosion on it......should I just get another oem MINI coil, or is there a better aftermarket "performance" option out there?
Thanks guys!
Old Jul 9, 2020 | 05:32 AM
ramjet77's Avatar
ramjet77
I think the consensus of the knowledgeable people on this forum is that "performance" coils do not offer any improvement and just stick with OEM.
Old Jul 9, 2020 | 08:21 AM
SupeR53's Avatar
SupeR53
Check your plugs as well, I had one that had microcracks from the factory, it took me a long time to diagnose it as I "knew" that the plugs were good as I'd just changed them....It had an 1/8" wide carbon track all the way down the insulator-obvious once I pulled the plugs.
Old Jul 9, 2020 | 10:27 AM
cooper48's Avatar
cooper48
Turn off your DSC at startup and see if that helps.
Old Jul 9, 2020 | 12:02 PM
IQRaceworks
I don't think it's a traction control issue......it will do it going 70mph down the highway sometimes. But I can give it a try.
The car is 17years old, and has 180K miles on it........The current plugs and wires have around 30,000 miles on them....and the coil is the original. I went ahead and order new plugs, new wires, and a new coil today....I'm hoping that will cure the issue.
Old Jul 9, 2020 | 02:31 PM
Soul Coughing
Indulge me and throw just the new coil on and see if that helps the situation. Crazily I had a coil fail on my Mini recently, so i bought a brand new OEM mini coil, and that too failed within 3 weeks, and then the replacement finally cured the issue. Basically would misfire under load and when it reved above 4.5k rpms.
Old Jul 9, 2020 | 03:50 PM
IQRaceworks
Yep.....I think I will do the coil, then take it for a drive. Then do the plugs...take it for a drive. Then wires....and take it for a drive.
I'm curious to see what is causing the actual problem.
Old Jul 10, 2020 | 12:20 AM
nd-photo.nl's Avatar
nd-photo.nl
My first guess would also be bypass valve, other things are fuel delivery/ignition (most likely). Good luck, following this thread!
Old Jul 10, 2020 | 04:59 AM
IQRaceworks
I have a boost gauge, and the boost is not dropping off when it does the bobble/missfire thing...so I don't think it's the BPV. I'm guessing ignition also....I should know next week when my parts come in.
Old Jul 10, 2020 | 08:10 AM
nd-photo.nl
Agreed, then the BPV is alright.
Old Jul 13, 2020 | 04:59 AM
IQRaceworks
***UPDATE***
Well, my new coil never came in on Friday like it was supposed to, but I did get my new NGK plugs and wires. The terminals on the old coil were all corroded and looked horrible. I cleaned them off, installed the new plugs and wires, and so far...the car is running great. Not sure if I will install that new coil when it shows up, or just return it. So far so good.....
Old Jul 13, 2020 | 06:28 AM
nd-photo.nl
I would install it for peace of mind, keep the old one as a spare unit.
Add a small dab of dielectric grease on the connectors > https://www.farmandfleet.com/blog/wh...%20connections.
Old Jul 13, 2020 | 09:56 AM
Soul Coughing
Originally Posted by IQRaceworks
***UPDATE***
Glad you got it sorted! Corroded connections would definitely do that!
chrisd
Jul 13, 2018 05:43 PM
user 7398330
Oct 25, 2013 10:17 PM
2003minicooper
May 3, 2012 03:57 PM
simpsonna
Nov 4, 2010 10:22 AM
Johan
Feb 16, 2006 12:51 PM
