Phone paring help please
sad to say but steering wheel had controls whether or not BT was installed ....
try a VIN decoder to check the original options ....
try: https://www.mdecoder.com/
I ran my 07 and it correctly said BT was NOT installed but was available as on add on (at the original time)
ran my R59 and it reported correctly for this as well . . .
not how it worked on my '15 (still GEN2) but worth a try . . .
<the process is so convoluted on my '15 that when Mrs changed phones it took me better than 30 minutes to stumble thru>
BUT ...
I believe 'bottom line' is what happens when you select 'phone'?????
if NOTHING ... I suspect BT is not in your car ....
BUT ...
I honestly can’t remember how I paired my 09. I paired it before we even pulled out for test drive and the rest is history.
Thanks for the replies!!! I guess mine didn't have the bluetooth option installed. According to the Vin decoder tool on the site it says "Mobile phone prewire *Late Availability*" and mine was produced in June of '07.
do you want the BT for music or phone capability?
You know that you can play music simply by running an audio cable from the headphone connection to the AUX port?
and for phone there are adapters that connect to the AUX port ...
you won't have control thru steering wheel but basic sound can get to speakers . . .
Unfortunately, retrofitting Bluetooth functionality is not as simple as swapping the head unit. You also need to:
- Install the ULF-SFX-Hi module (the actual Bluetooth interface) which lives under the drivers seat;
- Install the Bluetooth aerial (which is mounted under the center column);
- Install the microphone module into the overhead console;
- Modify the wiring harness to add the missing wiring;
- Install the optical fiber cabling (MOST bus) between the ULF and the radio; and
- Code everything up either using ISTA/P or NCSExpert.
Navigation & Audio How to get my music to play from iPhone via Bluetooth?
Systemlord
12
Jun 8, 2013 11:13 AM
Navigation & Audio iPhone 3g bluetooth sync help
lilliux
11
Jun 30, 2011 07:55 AM
Navigation & Audio Voice command, cannot make it work with iPhone...Any help?
gvamty
Mar 15, 2008 09:16 PM
