R56 What is this red handled "plug" for?
Old May 19, 2020 | 02:01 PM
Rewind's Avatar
Rewind
What is this red handled "plug" for?? I see it on the back side of my valve cover. (pic for reference)
Old May 20, 2020 | 12:53 AM
Staxtis's Avatar
Staxtis
Oil check..?
Old May 20, 2020 | 06:47 AM
Rewind's Avatar
Rewind
No, I don't think it's that....
Anyone else???
Old May 20, 2020 | 09:09 AM
cooper48's Avatar
cooper48
Jump out to realoem.com and see if you can ID it.
Old May 20, 2020 | 09:43 AM
Rewind's Avatar
Rewind
I did, no luck.
Old May 20, 2020 | 09:53 AM
Mineeee's Avatar
Mineeee
Its a secondary PCV I think?
Similar to this one?
https://www.ecstuning.com/b-mtc-part...127646555~mtc/
Old May 20, 2020 | 09:59 AM
Pull to inflate...
Its just for shipping, pull it out and replace it with the plug in the Baggy included. Its pictures below the valve cover in this pic below.
https://www.northamericanmotoring.co...ment-help.html
Old May 20, 2020 | 10:19 AM
Rewind's Avatar
Rewind
Thank you for the response. The reason I'm asking is I saw this on the cover of my mini, but it has not been pulled, was that way when I got the car, and I don't have the appropriate plug. Should I try to find a plug and pull this out and replace?
Old May 20, 2020 | 10:23 AM
Yep that red plug might get bumped and wiggle out. Then you might get a vacuum leak code.
We are the only people that have it on its own for people that forget to replace it.
https://www.ecstuning.com/b-hamburg-...27646555plug~/
Old May 20, 2020 | 11:11 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Why would that plug not even be already installed on the cover?
Old May 20, 2020 | 11:14 AM
Shared with other brands on the cover, PSA and Citroen. Person forget to install it?
Old May 20, 2020 | 06:51 PM
mildensteve's Avatar
mildensteve
The older original valve covers like the one on my 08 don't have the port so no plug. As ECSTuning states it is for other applications. I have seen instructions somewhere that you just cut off the loop with some wire cutters. The port isn't really presurized so the plug stays in place. It is to keep the PCV system vacuum tight so no big deal. Use some black paint if the red bothers you.
Old May 20, 2020 | 06:59 PM
zrickety's Avatar
zrickety
That's funny, when I pulled my intake manifold this little plug was sitting on one of the bolts. Now I know what it's for...
Old May 21, 2020 | 08:47 AM
Rewind's Avatar
Rewind
So, other than the chance it might fall out there is no reason to pull it out and replace it?
Old May 21, 2020 | 08:53 AM
Chance as last time when i replaces mine it was in there (pulls out easy) and if not removed it hits most intakes and aftermarket intakes even sit closer to it. I had an AEM intake system on my MINI and its comes very close to that plug part. If i did not have the black plug in it would not fit with that red thing there unless you trimmed it all the way down.
Old Jun 4, 2020 | 06:59 AM
Did you get it fixed?
Old Jun 4, 2020 | 09:01 AM
Rewind's Avatar
Rewind
I have not addressed this as of yet, had other things to take care of. Is there any harm in leaving it as is for awhile? Why is shipping $8.00 for such a small part?
Old Jun 4, 2020 | 10:16 AM
Hello,
Should be ok as long as it does not fall out or get bumped. Thats our flat rate or staring shipping rate. if you build an order to 49.00 you get the free shipping.
Old Jun 8, 2020 | 09:33 AM
z168's Avatar
z168
Gotta love ECS support
When are you guys going to start supporting Tesla
Old Jun 9, 2020 | 08:04 PM
We have a MINI E support, need to add that to the drop down and we support BM i3 and i8. Maybe in the future. We can get about anything for any car with all our connections. Just contact us and one of the sales guys can track it down or PM me.
Old May 25, 2022 | 04:25 PM
JamesMason15's Avatar
JamesMason15
How about this one?
Old May 26, 2022 | 06:32 AM
Same thing. It makes your MINI grow when you pull it.
BTW we have the N18 Engine valve covers here: https://www.ecstuning.com/Search/Sit...8_valve_cover/
Old Jun 4, 2022 | 11:04 AM
Mini242's Avatar
Mini242
Recently bought the valve cover from you guys. A must over 50k miles it seems. The oil cap seems a bit loose with the new cover. Any suggestions?
Old Jun 6, 2022 | 05:37 AM
Hello,
Might be the gasket itself. or you did not crank down on it all the way, the aftermarket ones seem to have to be turned a little tighter. Try that first.
blackjackmark
May 20, 2008 06:51 AM
blacknblue
MINI Camera and Video
Jul 26, 2005 09:09 AM
Alex@tirerack
Tires, Wheels, & Brakes
Nov 18, 2004 01:32 PM
MiniLuvr
May 11, 2003 03:59 PM
