Clutch safety switch
Old May 18, 2020 | 08:50 PM
Boostedmini420's Avatar
Boostedmini420
Hey yall im new to the fourm I have a 2011 mini cooper jcw that i just bought last week. Today while coming up to a light i pressed in the clutch and heard a crunch sound when the light turned green and i tried to take off the car wouldnt go into gear after pushing to the side of the road it wes ouldnt restart i believe because safety switch. Can someone tell me the proper procedure to remove the switch and how to test it with my multimeter and test light.
Old May 19, 2020 | 10:28 AM
gareese's Avatar
gareese
I don't have any direct experience with this issue. But this article may help. Good luck and post back your results/fix.
https://www.pelicanparts.com/techart...eplacement.htm
Old May 21, 2020 | 12:06 PM
Boostedmini420
I figured out what i broke the master cylinder pin that conets it to the clutch pedal broke (stupid plastic parts) anyways i went to the hardware store and got a bolt that fits and reconected it but now when i press the clutch it feels soft and spongy and wont shift into any gears dose this mean i need to replace the master and slave cylinders? Im going to try bleeding the system today hopefully that fixes the issue.
Also should the spring be coated in grease like that?
Bodyartcrazy
Oct 4, 2021 09:50 AM
Warden Brian
Dec 26, 2019 06:03 PM
MiniMacster
Jul 8, 2019 01:59 PM
finfin
Electrical
Nov 27, 2014 02:15 PM
rolfiesb
Jan 22, 2011 05:47 PM
