R56 Automatic Shift Knob
Old May 12, 2020 | 03:08 PM
Mini242's Avatar
Mini242
R56 Automatic Shift ****
My button stopped working recently. The car was only able to shift into R, N, D and of course semi tronic into other gears.
My question is do I need that button? Can I switch to a manual **** without loosing function? Can my car be shifted into neutral more easily without the button.
I just don't want to spend $100+ on an auto **** with a button if I don't need to.
I have been shitfing without the part below for a day or so. do I need the button? what is it's function?
Old May 18, 2020 | 08:39 AM
MiniToBe's Avatar
MiniToBe
they are not interchangeable. The manual shift **** is just a ****. you need that rod to pushes on a lock inside the shifter housing. try to push the shifter down, maybe it came out a bit and is not functioning properly.
Old May 18, 2020 | 12:12 PM
Mini242's Avatar
Mini242
Thanks for the reply. The spring in the know siezed up so now it is not functioning. My remedy so far has to simply remove the part and/or just toggle the gears manually.
Now I guess I have to replace the part.
cmdycrzr
Apr 17, 2020 12:33 PM
MAC33
How To
Aug 5, 2019 04:12 PM
cmdycrzr
Mar 24, 2018 08:19 AM
mitymouse
R55 :: Clubman Talk (2008+)
Aug 29, 2017 09:11 AM
Ive's Mini
Dec 2, 2014 05:28 PM
