Wheel stud conversion
Old May 11, 2020 | 05:25 PM
Kitchenboy's Avatar
Kitchenboy
Can anyone tell me what wheel stud conversion kit I would need for my 2008 R52 JCW. I just bought a set of OZ racing wheels and I was thinking of doing the conversion instead of buying black lug bolts. Is it worth doing and who is the best place to get them from. Thanks for any help. These are the wheels.
Old May 11, 2020 | 05:37 PM
Eurothrasher's Avatar
Eurothrasher
I got my set from ECS Tuning...they've done all the homework already so easy to figure out....esp if your running wheel spacers...
Just put in the info on your MINI and go to the wheels section.
Old May 11, 2020 | 05:58 PM
Kitchenboy's Avatar
Kitchenboy
I was on a chat with ECS but when I put R52 and he asked if it was a couple or convertible I got nervous. Plus being an 08 but actually a first gen gets confusing sometimes.
Old May 11, 2020 | 06:08 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
This would be the correct stud kit for an 08 R52
https://www.waymotorworks.com/m14x1....-stud-kit.html
Old May 11, 2020 | 06:20 PM
Eurothrasher
Chat ?
Hahaha....
https://www.ecstuning.com/b-ecs-part...t/prf75ch5kt7/
When and if it comes time to remove the studs, say if installing new wheel bearing....use two on one spline tighten them up against each other, then put the wrench on inner nut to back it out....This explains the technique for all studs on a car but you get the idea.
Kitchenboy's Avatar
Kitchenboy
Thanks Way. One more thing I'll be doing when I get the car back from you. What nuts would I use. I'm not running spacers and dont know if I'll like the look of the studs sticking way out of the nuts.
Old May 11, 2020 | 07:17 PM
Hello,
Yep their is a split year in 7/2006 when they changed the thread pitch and size. If you need help in the future I am always here.
2008 MINI R52 here: https://www.ecstuning.com/Mini-2008-...s/Wheel_Studs/
Sold out due to the sale demand but we will have them back in soon.
Old Nov 19, 2021 | 08:49 AM
bump32's Avatar
bump32
I need some clarification on wheel studs as well.
2006 R53 with M14 x1.25 lug nuts.
I have two sets of wheels. My Konig track wheels needed to be drilled ever so slightly from 13.3mm to 14mm and they are still snug. They also take a centering ring. I don't plan on purchasing new wheels any time soon but I've heard most aftermarket wheels are easier to mount with M12 studs because they may need to be drilled for M14? Is that correct?
Questions:
... The wheel stud kits do not say M12 or M14???
****EDIT: It actually does say on the KIT CONTENTS tab.
If I add an 8mm spacer then my centering ring for the Konig wheels will have nothing to sit on? I should go measure but my assumption here is that an 8mm spacer will still allow me to us the centering ring????
Should I go to a M14 to M12 conversion stud?
https://www.waymotorworks.com/m14-to...rsion-kit.html
Is the strength of M14 over M12 worth staying with M14? (I may put 5-10mm spacers on my stock wheels)
Thanks in advance.
Old Nov 22, 2021 | 11:02 AM
deepgrey's Avatar
deepgrey
A lot of aftermarket wheels do seem to be drilled too small for the 14 mm studs. I've been running the WMW M14 to M12 conversion studs for a few years for that exact reason. They have a bit of surface rust, but otherwise they seem to be holding up fine. I'll probably swap them for studs with a different finish sometime soon-ish. Unfortunately, I can't answer any of your other questions. I don't run spacers or track my car.
F56-JCDub
Jun 13, 2018 09:41 AM
csgirardeau
Sep 27, 2016 02:06 PM
WayMotorWorks
Tires, Wheels & Brakes
Dec 14, 2015 02:15 PM
jezter
Suspension
Apr 7, 2010 06:11 AM
SomethingNew71
Tires, Wheels, & Brakes
Apr 17, 2008 06:27 PM
