Compression Check
Old May 11, 2020 | 12:57 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Compression Check
Does anyone have a "How To" on checking the compression of an N18 engine? With all the engine systems tied together, not sure how to proceed.
Old May 12, 2020 | 09:29 AM
MiniToBe's Avatar
MiniToBe
The way I do it is by removing all the spark plugs so the starter isnt pulling too much amperage. Then, remove the fuel pump fuse. after that, insert the gauge and start the car, let it crank few times until the gauge needle cannot go up anymore.
Old May 12, 2020 | 09:45 AM
MVPeters's Avatar
MVPeters
Originally Posted by MiniToBe
The way I do it is by removing all the spark plugs so the starter isn't pulling too much amperage. Then, remove the fuel pump fuse. after that, insert the gauge and start the car, let it crank few times until the gauge needle cannot go up anymore.
& put a brick on the gas pedal so that the throttle is wide open.
Look for all 4 readings to be within about 10% of each other.
BRracing
Oct 24, 2015 10:07 PM
VX crazy
R58 :: Coupé Talk (2012+)
Feb 7, 2014 05:05 PM
RodLentin
Aug 7, 2013 04:11 AM
Audiophile_Mark
R59 :: Roadster Talk (2012+)
11
Nov 1, 2012 08:38 AM
moseichuk007
Feb 18, 2009 11:32 PM
