R56 Learning
Old May 9, 2020 | 04:52 PM
Minifenrir's Avatar
Minifenrir
Learning
Ok so as I did more and more into my new 2011 Cooper S I'm learning more about it. So previous owner installed the JCW brake duct work , complete kit not just the grill ports, my exhaust has the down pipe cat and the flex joint then is straight thru to the rear muffler with dual center outlets. Still haven't dug into it to see if there is an after market diverter valve but it does have the Forge type boost tap under the IAT sensor in the intake manifold. I was looking into the noise maker delete and it appears my car never had one. There is no joke thru the firewall where one would have gone but I do have to remove the IC muffler soon. My car has a build date of January 2011.
Old May 9, 2020 | 07:12 PM
Jason Cornelius's Avatar
Jason Cornelius
There is a factory noise maker delete that came on the JCW’s, you can buy the part separately. Run your vin, might be a jcw.
Old May 10, 2020 | 04:03 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
N18 engines didn’t have the noise maker pipe.
LCI R56 Cooper S front bumper had brake ducts as stock.
If there is no cat or resonator in the exhaust, it is an aftermarket system.
Old May 10, 2020 | 05:36 AM
Minifenrir's Avatar
Minifenrir
Good to know thanks njaremka. I think my exhaust is stock with a resonator delete. It appears to have a welded in section about midway between the flex joint and the rear muffler.
Bald Headed Traveler
Apr 29, 2020 08:56 AM
Cab00se
Mar 30, 2019 04:25 AM
JohnDoe11
R55 :: Clubman Talk (2008+)
23
Sep 27, 2015 02:11 PM
bdrecksage
Aug 5, 2013 01:37 PM
korre07
Jun 18, 2013 11:42 AM
