F55/F56 Updating to Union Jack Brake Lights
Old May 5, 2020 | 11:26 AM
rphox2003's Avatar
rphox2003
Hi,
I recently updated my 2017 Justa with the Union Jack brake lights. My stock lights were not LEDs. The place that did it said they coded the new lights but the lights would flicker on start-up. I looked around this forum, found the solution, and used my OBDII reader to fix the coding.
Since then, a local club member has posted a comment that eBay is selling lights that have already been coded. I replied that I thought the coding is in the car's ECU, not the lights.
Can anybody shed some light on this issue? TIA.
Old May 7, 2020 | 09:57 AM
robby71's Avatar
robby71
There are some seller who list on Ebay but the light are aftermarket and cost more than genuine ones.
These are plug and play as i believe they have resistors built in to stop the warnings on dash and flickering.
The flicker on start up with the genuine ones is coded out with Bimmercode by changing the options for each light to LED and then changing all cold and warm monitoring options from active to deactivate
Old May 7, 2020 | 11:40 AM
curlywurly's Avatar
curlywurly
What Robby71 says
IMHO youve chosen your path by buying the OEM quality lights and using bimmercode and removing codes.
Your mate on your local board prefers buying the non OEM lights with an additional electrical box wired in to negate any coding. Different solution to same problem
Andriod mentality vs ios would be a relatable problem/solution route.
To complicate there are third solution - kinda a hybrid of the two - mulgari offers OEM lights with the additional module to trick modules/remove the need to code. You can see the clunky box in the pics...
https://mulgari.com/shop/exterior-st...-upgrade-pack/
Old May 9, 2020 | 11:22 AM
rphox2003's Avatar
rphox2003
Thanks.
Old May 18, 2020 | 10:45 AM
gtbrooklyn's Avatar
gtbrooklyn
How you guys doing? Just putting this out there to see if anyone had the same issue and how they resolved it. So I have a F57, 2017 Cooper S, Convertible with the Halogen lights. I just purchased a pair of European Tail Lightshttps://www.ebay.com/itm/BMW-MINI-OE...72.m2749.l2649. After installing and Coding, the error on the dash went away, but the tailights doesn't light up. The turn signal works and the brake light works, but I cant get the Union Jack to light up, I followed all the directions to code it, and it's still not activating. Did any of you guys had that issue? and how did you resolve it?
Old May 18, 2020 | 11:46 AM
bluonyx's Avatar
bluonyx
I thought the union jack area only lights up as the parking lights are turned on.
Old May 18, 2020 | 11:52 AM
gtbrooklyn's Avatar
gtbrooklyn
No, the Union Jack is the actual tailights.
Old May 18, 2020 | 12:53 PM
robby71's Avatar
robby71
Union Jacks light up when headlights or sidelights are switched on. You can use Bimmercode to activate then to work as DRLs so when ignition is on so are the lights
Old May 18, 2020 | 01:00 PM
robby71's Avatar
robby71
Sidelights on
Brake Lights only
Tail, Brake, Hazards on
Old May 18, 2020 | 01:09 PM
gtbrooklyn's Avatar
gtbrooklyn
My problem is my sidelights are not on. So I am not sure if I need to repin 1 to 5 since I am going from strictly Halogen to LEDS.
Old May 18, 2020 | 01:49 PM
bluonyx's Avatar
bluonyx
I had tried to purchase the Euro ones and couldn't get them to work so I just ended up returning them. I already had LED union jacks, I just liked the look of the Euros better.
Old May 18, 2020 | 02:19 PM
gtbrooklyn's Avatar
gtbrooklyn
That's weird, I would think they would be PnP, or at least minimum coding since yours was already LEDs.
Old May 18, 2020 | 02:28 PM
robby71's Avatar
robby71
Have you tried with the light switch in all positions?
If you have 6 wires to each connector you don't need to swap the pins but if you have 5 then you do
6 wires
Old May 19, 2020 | 06:30 PM
gtbrooklyn's Avatar
gtbrooklyn
Union Jack Tailights now working.
So a quick update. I finally got them working by switching pin 1 to 5 and coding out the errors
Big shout out to Robby71 and DunkM. They were a valuable source of help to me. Thanks again guys. This is one hell of an upgrade.
Old May 20, 2020 | 02:25 PM
robby71's Avatar
robby71
Glad you got it sorted in the end
Old May 22, 2020 | 08:26 AM
Looks great!
Old Mar 8, 2021 | 07:45 PM
danielngho's Avatar
danielngho
Brake light doesn't light up
6 wires
Hello, I know this thread is waaay back.
I recently purchase the Union Jack Tail light, but somehow, I can't get the brake to work. Turn Signal work, and union jack work as running light, but the vertical stop light, doesn't light up.
My car has 6 pin connector. Coded out the error message, and still doesn't work. plugged back in the old tail light and stop light do light up. connected new tail light to the LCI and works. mine is 2015 F55s
Old Oct 8, 2021 | 07:43 PM
BoostedJ's Avatar
BoostedJ
Were you able to figure this problem out?? I just installed on my 2016 f56 jcw and Im having the same problem with the addition of the turn signal acts as the brake light. Any help would be appreciated. Thank you
Michael Bencosme
Apr 2, 2021 04:38 PM
FunToMini
Feb 11, 2020 01:18 PM
Daniele Ccc
Nov 29, 2019 02:19 PM
RCgreymini
May 30, 2019 01:38 PM
empire0007
Electrical
35
Jun 28, 2013 10:46 AM
