R56 Bulb check warning light and CARLY app
Old Mar 27, 2020 | 05:04 AM
Monstertails's Avatar
Monstertails
I installed led headlight bulbs in my 2010 r56 base model, and using the supplied adapters i was able to get the headlight bulb warning to turn off. I tried to install led bulbs in the lower parking lights but get the warning. Does anyone know if I use the CARLY app to turn off the warm and cold bulb checks will this allow me to use led light bulbs in my lower parking lights without getting any warnings?
Old Mar 27, 2020 | 06:18 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Yup. You should be able to turn off all the bulb checks in the Carly app.
Old Mar 27, 2020 | 07:19 AM
Monstertails
Awesome! Thank you. I know it’ll turn off the issue that causes my headlights from Strobing, I just wanted to make sure it will turn off the issue that sets Off the warning. The car looks real good with LED headlights but the incandescent parking lights really bring it down.
Old Mar 27, 2020 | 07:37 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I have almost all my exterior lights converter to LED, with the exception of the fender markers. (have some on order from EBay) I used the Carly app to decode the bulb checks.
My car has factory HID headlights, too.
Old Mar 27, 2020 | 09:54 AM
Monstertails
Thanks for getting back to me, what exactly do you turn off? is it the warm and cold bulb checks?
Old Mar 27, 2020 | 10:40 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
My understanding is the cold check is performed at start-up, it is the rapid flashing often seen when LEDs are installed. The warm check monitors the bulb during operation, and senses if the bulb goes out during use. I turned them all off
Old Mar 27, 2020 | 11:09 AM
+1 yep I call it when leds are installed the cop lights. no matter if you have canbus or non canbus leds.
Old Mar 27, 2020 | 11:43 AM
Monstertails
I agree and it’s super frustrating! Nothing like, looking like a tool and drawing attention to yourself!
Old Mar 27, 2020 | 11:45 AM
Monstertails
I have been wanting to get The Carly app for a long time and this just broke the camels back
Old Mar 28, 2020 | 05:49 PM
Monstertails
well I paid the 63.00 for the Carly app tonight and was able to get my headlights to stop flashing!! Now the only issue I am still having is I still get the bulb out warning when I try to replace my lower parking light bulbs with LED bulbs. I cant find anyway to get LED bulbs to work in sockets. They will light up but it shows the bulb issue on the tach. Does anyone have info that can help me solve this?
Old Mar 29, 2020 | 04:06 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
There should be a setting in Carly to turn off The bulb checks for each bulb location, not just one blanket setting for all bulbs.
Old Mar 29, 2020 | 08:26 AM
Monstertails
I went through the whole app meticulously and did find Light voltage checks for everything, but nothing for the front parking lights. I went through and I turned off voltage checks for every light system in the car, There was even a setting for Angel eyes which I don’t believe my car has and I turn that off. The moment I insert the LED bulbs in the parking light sockets it kicks off a code . So super frustrated
Old Mar 30, 2020 | 04:46 AM
Crossingover's Avatar
Crossingover
BimmerCode is a good alternative. I used it to toggle all the warm and cold lamp current monitoring OFF on my 2013 MC as well as a few other convenience items. Plus I am able to use a generic OBD adapter that I had laying around for my other vehicles.
Old Mar 30, 2020 | 05:22 AM
Monstertails
Did BimmerCode give a parking light option? I have a Generic adapter that I am using for the Carly app. It works for most ecu’s on the car just not the safety Ecu. The only other issue is that it is WiFi not Bluetooth and l tried to download the app to test it would not connect to my phone. I am using a ELM 27 adapter
Old Mar 30, 2020 | 05:31 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I could have sworn there was an option for the parking lights... Is it labeled "upper fog light" or something like that?
When I get a chance, I'll go connect to my car and see what I can see.
Old Mar 30, 2020 | 05:36 AM
Monstertails
Thank you. I Literally turned everything off on the Carly app regarding voltage checked with lights. For some reason I can’t figure it out
Old Mar 30, 2020 | 06:46 AM
jwzimm's Avatar
jwzimm
I have found that the Carly App does not have every option programmed for the light checks. Since it is a manual process for them to set up the coding (they are basically writing scripts to perform the coding changes) they seem to only have done the "popular" codes. It also appears that Carly is not updating their app for any new codes for the Mini.
Honestly the best solution to this is to learn to code the "hard" way using a netbook/laptop and NCSExpert. The learning curve is rather steep though. The upshot is you can do literally anything that you want with any code and also possibly discover new options. I have yet to tackle the challenge on the Mini. I used to code on my BMW's and it isn't super hard, you just need to be careful and follow the guides meticulously. Plus, everything is in German so you will end up learning some choice German words. :p
Edit, there is a couple of threads in the Electrical section that go over how to get started with coding and what options other have found:
https://www.northamericanmotoring.co...beginners.html
https://www.northamericanmotoring.co...-yourself.html
Singer2345
Electrical
May 10, 2022 02:40 AM
Legates01
R60/R61 Stock Problems/Issues
Jun 12, 2017 11:51 AM
Moonman
Nov 4, 2015 08:48 AM
mini_mini
Electrical
Nov 27, 2012 10:44 PM
jayk
Jan 6, 2010 07:15 PM
