What are these parts?
Old Mar 23, 2020 | 10:18 AM
Michaelh57's Avatar
Michaelh57
Sometimes when I’m driving I’ll notice a burny smell/like something just isn’t right. Not sure if this is normal or not, I know it’s probably not. I was looking around the engine bay and noticed that inside the silver thing the arrows are going to, it is cracked around the cap/seal. Not sure what they are if that might be it.
i also just got my oil changed two days ago and the engine cap had some gunk on it that I wiped off to see if it reappears. Thank you all for your help.
*Picture is not my car*
Old Mar 23, 2020 | 11:24 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
"the silver thing the arrows are going to" are the shock towers. The rubber bit on the inside is the actual shock mount. If those are cracked, they need to be replaced before your handling goes all wonky.
If there was "gunk" on the oil cap, the monkeys that changed the oil might have gotten oil on the exhaust. That could be the source of your smell, but it is near impossible to diagnose a smell over the internet. (almost as difficult as diagnosing a noise)
Old Mar 23, 2020 | 12:43 PM
Michaelh57's Avatar
Michaelh57
Yes the rubber on the inside is what is cracked not the metal. What can I google to find the parts themselves and is it difficult. The smell comes through my air vents into the cabin. It’s not from the exhaust.
Old Mar 23, 2020 | 12:49 PM
Michaelh57's Avatar
Michaelh57
Also is it safe to drive right now? I don’t really have another vehicle so I’d have to carpool until it’s repaired.
Old Mar 23, 2020 | 12:50 PM
y8s's Avatar
y8s
The smell can indeed be burning oil from an oil change (burning off the exhaust). If it doesn't go away in a week, or change with recirculate on, keep looking.
Old Mar 23, 2020 | 12:51 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
How many miles on the car? Might be time for a full suspension refresh.
https://www.ecstuning.com/b-bilstein...t/22-170996kt/
https://www.ecstuning.com/b-assemble...31306772749kt/
Again, for the smell, can't help you there...
Old Mar 23, 2020 | 01:01 PM
Michaelh57's Avatar
Michaelh57
Car has 72,000 miles on it. And ok, the smell comes and goes. It’s gone more then it’s there
Old Mar 23, 2020 | 01:11 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
My guess is oil on the exhaust, or something like that.
The suspension bits should be OK to drive on, but you'll probably want to take care of it sooner rather than later. Just keep an eye on those shock mounts until you can get them replaced.
Old Mar 23, 2020 | 01:17 PM
Michaelh57's Avatar
Michaelh57
Ok thank you for the help, is it a dyi job? I don’t have a lot of mechanical experience pretty much just oil change and changing brake pads is about it.
Old Mar 23, 2020 | 01:20 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
In theory, changing the suspension is not a difficult job, but definitely much more difficult than changing oil. There are how-to's out there, and you will need some specialized tools.
Old Mar 23, 2020 | 01:26 PM
Michaelh57's Avatar
Michaelh57
Ok, thank you again for all your help I appreciate it.
Old Mar 23, 2020 | 01:28 PM
mikey_t's Avatar
mikey_t
I think you should leave any repairs (other than an oil change & maybe the brake pads) to those who do it for a living or know exactly what they are doing.
Old Mar 23, 2020 | 02:26 PM
Michaelh57's Avatar
Michaelh57
Just got out of work here is a picture of mine just to confirm one last time before I buy the part.
Old Mar 23, 2020 | 02:38 PM
MVPeters's Avatar
MVPeters
Michaelh
No need to carpool yet!
That mount is beginning to fail though, so I'd arrange to get them both changed when you can.
I'd use an independent MINI garage & have them check for 'mushrooming' of the towers while they are in there.
Meanwhile, tighten up the 3 bolts on the top of each tower - it looks like at least one of them is loose.
Old Mar 23, 2020 | 02:49 PM
Michaelh57's Avatar
Michaelh57
Ok thank you very much for the information. What exactly mushrooming? Also what’s a reasonable price I should expect to pay so I don’t get ripped off
Old Mar 23, 2020 | 03:05 PM
MVPeters's Avatar
MVPeters
'Mushrooming' is the top of the shock towers being pushed up - the 3 bolts should be perfectly vertical (& tight!).
It's a very common problem & there are many threads on here - just search for 'mushroom' & you won't be kept in the dark.
Sorry, I don't know about the cost, but it's not huge.
Old Mar 23, 2020 | 03:41 PM
Michaelh57's Avatar
Michaelh57
Ok thank you very much everyone for your help and advice
Old Mar 24, 2020 | 09:02 AM
2012_R60's Avatar
2012_R60
I did this a few months ago on both sides. I ordered the LEMFORDER strut mounts from ECS it’s not a hard job but it takes a few hours. If it’s your first time I would book off the whole day for it. You’ll also need an alignment afterwords since you take both shocks off. Check newtis for step by step. The only special part I used was the shock compression tool that I rented from autozone.
If you haven’t worked on cars before though besides oil changes I would suggest you take it to a shop. If it’ll take you the good part of a day to do it your time might be worth more than paying an Indy shop to do it.
Old Mar 24, 2020 | 09:53 AM
Yep, mine did that on my R56 and R52, they need replaced.
Countryman/ Paceman kits are here: Cup kit/coilover kit is what you need.
https://www.ecstuning.com/Search/Sit...ation_Kit_R60/
tdskip
Feb 21, 2017 10:59 AM
KaptainKrista
Dec 24, 2014 12:00 AM
Llanrhaeadr_Cymru
Apr 13, 2012 10:45 AM
05Greenie
Mar 23, 2011 04:07 PM
CharlesT
Apr 25, 2003 08:34 AM
