R56 Normal to feel puffing with oil cap removed and engine running?
Old Feb 21, 2017 | 08:24 AM
tdskip's Avatar
tdskip
Good morning - my R56 has about 92,000 miles on it and this morning I removed the oil cap while the car was running and I could feel fairly strong pulses of air when I held my hand over the now open oil cap neck.
Is this considered normal for a healthy engine?
Thanks!
Old Feb 21, 2017 | 09:19 AM
HasAnMTBProblem's Avatar
HasAnMTBProblem
On every engine I've ever worked on, you were't supposed to have the oil cap off with the engine running. The rockers/valves sling oil pretty good, typically. So, I'd have no idea if that was normal or not. I could see it being a normal thing, though, considering oil pressure would cause air pressure. Combined with the rockers/valves moving, it would seem reasonable to feel slight puffs of air. However, I'm not a pro. So, maybe someone has another opinion.
Incidentally, why do you have the oil cap off with engine running?
Old Feb 21, 2017 | 09:28 AM
gumbedamit's Avatar
gumbedamit
+1
Yes, there is pressure in the engine that would cause your puffs, WHY WOULD YOU TAKE THE OIL CAP OFF WITH THE ENGINE RUNNING?????
Old Feb 21, 2017 | 10:11 AM
HasAnMTBProblem
Originally Posted by gumbedamit
+1
LOL. One time, when I was much younger, I accidentally left the oil cap off after an oil change, or something. I forget what clued me in (probably started seeing smoke) but when I opened the hood, there was oil slung all over the underside of the hood. Luckily, the cap was pinned between the hood and the engine.
Old Feb 21, 2017 | 10:42 AM
tdskip's Avatar
tdskip
Good morning thank you for the responses. It's not it's completely crazy as it may seem if you're mostly familiar with British cars. That's a quick way to see if your upper rocker shaft is getting oil if they are already blow by issues. Car was stationary with bonnet iup already and I was curious as I have some oil leaks / oil consumption issues.
Old Feb 21, 2017 | 10:59 AM
HasAnMTBProblem
Now how "British" I'd consider modern Mini's to be.
