R50/53 $500 bargin Mini-Airbag Light
Old Mar 18, 2020 | 05:37 PM
robj's Avatar
robj
After 6 months work I have been driving the $550 Bargain Mini since Saturday and have about 250 miles so far. Too much fun, sounds terrific and hasn't missed a beat.
Night before last the air bag light came on, out of the blue. checked the seat connections, didn't find anything.
I have the Schawaben scan tool and founds codes for the airbag. Started doing research and found this discussion;
https://www.northamericanmotoring.co...g-light-2.html
I found a post that said;
"The Schwaben will clear airbag lights"
https://www.ecstuning.com/b-schwaben...020sch01a~scf/
I Couldn't make it happen. Any hints?
I think I found the same code in each category
Codes found in each category
Message I got when trying to delete.
Is it actually possible to delete these codes with the Schwaben? If so anyone have the steps so that even a dummy can understand?
robj
Old Mar 19, 2020 | 04:44 AM
deepgrey's Avatar
deepgrey
I'm pretty sure the Schwaben is supposed to be able to clear them, but I don't think it will if you have an actual fault that hasn't been fixed.
Old Mar 19, 2020 | 06:02 AM
iwashmycar's Avatar
iwashmycar
Do you have a sunroof?
Old Mar 19, 2020 | 08:35 AM
robj's Avatar
robj
Thanks Deep,
I did check the connection under the seat so I guess the next thing is to take the steering wheel off and check the connections there?
Anything else to check for an actual problem?
I just read so many posts where the light showed up out of the blue with no actual issue. I put my dog in the passenger side, then saw the light but the codes say "drivers side".
I was thinking to try to clear the light and see if it comes back.
Carwash,
And yes, I do have a sunroof. Does that affect anything with the airbag light? Please tell me it doesn't, even Mini can't be that weird...
Thanks,
rob
Old Mar 19, 2020 | 09:57 AM
Yes it will do it, i have done it. If you have a fault or it has trouble with communication to the module due to a problem with the module or a low due to a dead battery or weak connection to the ecu. Also a connection or wire between the airbag and system might be damaged. Sometimes low voltage to units can make this happen.
Old Mar 19, 2020 | 10:29 AM
iwashmycar's Avatar
iwashmycar
Originally Posted by robj
Carwash,
I had a second gen but yes....I had an air bag light because some part of the sunroof system chaffed a wire up above the passenger side. Mine was not very old (maybe a year) and luckily it was under warranty. I probably never would have found it.
Best of luck!
pnwR53S
Nov 3, 2017 10:29 PM
Mini Hooper
Sep 17, 2015 01:58 PM
jmoser
Jul 29, 2008 02:21 PM
Yo'sDad
Mar 17, 2007 12:29 PM
d2mini
Electrical
Oct 10, 2005 02:58 PM
