Radiator Hose bottom attachments
Old Mar 15, 2020 | 11:50 AM
mini-is-for-me's Avatar
mini-is-for-me
Does anyone have a part number for the plastic pieces on the radiator hose that connect up to the bottom and help support the radiator hose at the bottom of travel?
Old Mar 15, 2020 | 05:28 PM
cpmetz's Avatar
cpmetz
Maybe this one? Replaced one on one of my Minis recently.
11722756407 ?
https://www.rmeuropean.com/Products/...407-MFG26.aspx
Cheers,
Philip
Old Mar 16, 2020 | 04:39 PM
mini-is-for-me
Yes, that's it thanks.
Old Mar 18, 2020 | 09:07 AM
Yep talked about here:
https://www.northamericanmotoring.co...-cooper-s.html
They can drop down.
Old Mar 18, 2020 | 09:39 AM
mini-is-for-me
Thanks. Yes, I put a stainless steel tie wrap on this awhile back which is more reliable then this plastic thing. It looks like mine on one side where the steel tie wrap is on just maybe disconnected but it could be broken.
Old Mar 18, 2020 | 10:28 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Use a fat zip tie, or hose clamp as that stock clip breaks all the time
Old Mar 21, 2020 | 08:34 AM
Lancaster's Avatar
Lancaster
I like how much surface area there is with those clips as opposed to zip ties. There is also a black mesh that goes between these clips and the rubber hose.
Old Mar 22, 2020 | 10:11 AM
mini-is-for-me
What black mesh is that? I don't see that on mine. clamps have a cheap connector that attaches to the frame. That is the weak point in the design. Anyway, I can't really do anything in regard to this right now as there is no distilled water out there. None! Zilch. It has all been hoarded for the Apocalypse.
Old Mar 22, 2020 | 02:40 PM
I just saw some distilled water at walmart. Might want to check there.
Old Mar 22, 2020 | 03:16 PM
mini-is-for-me
It is insane here. 125 people in line at 7:am. Toilet paper, napkins, kleenex, water of any kind gone. It would make more sense if Covid was the worm they put down your nose in Star Trek that eats at your brain until you go insane. Otherwise, I have no idea what water and toilet paper does for a virus. Water comes out of the faucet here for drinking so...
WoodyWold
Jan 24, 2012 06:23 PM
martinbs
R55 :: Clubman Talk (2008+)
Jan 11, 2009 07:28 AM
betet
Nov 20, 2005 07:54 PM
