R55 Advice on cylinder 1 misfire?
Old Mar 1, 2020 | 05:30 PM
ronin729's Avatar
ronin729
2008 R55 Cooper. Clyinder 1 misfire code, changed plugs, swapped coil packs around, good compression, still throwing code and running rough. Any ideas what else it could be?
thanks
Old Mar 5, 2020 | 01:25 PM
chadtoolio's Avatar
chadtoolio
You really need to Oscope the signal wire coming from the DME....Also, do a resistance test on all of the wires from the coil pack to the DME. Sounds like a failed output stage
Old Mar 5, 2020 | 02:09 PM
chadtoolio's Avatar
chadtoolio
also, don't leave out the injector circuit.....3 things make em run-fuel, fire and compression
Apollo_33x
Jul 25, 2016 11:50 AM
2003minicooper
May 3, 2012 03:57 PM
JCampos
May 18, 2009 11:58 AM
OctaneGuy
Aug 24, 2007 11:28 PM
DarkMiniCooperS
Aug 18, 2004 10:35 AM
