R50/53 Vacuum Parts
Old Feb 26, 2020 | 01:10 PM
speedman's Avatar
speedman
Vacuum Parts
Does anyone have a list of the vacuum lines or a diagram that shows all of them. I have replaced
1) Brake Booster Line
2) MAP Sensor Line
3) PVC Line
4) Fuel Pressure Regulator Line
5) Fuel Breather line
What lines am I missing? Thanks!
Old Feb 26, 2020 | 02:06 PM
Grand-Cayman's Avatar
Grand-Cayman
3) PVC Line
How about check the PCV? [just kidding - couldn't resist ]
Old Feb 26, 2020 | 02:14 PM
tej98's Avatar
tej98
There are a couple more on the BPV/Throttle body that you could check. Also check the gasket that goes between the BPV and the intercooler horn. Mine was completely flat and I would have missed it had I not taken the BPV off the horn.
Old Feb 26, 2020 | 03:55 PM
speedman's Avatar
speedman
I am a country boy with dyslexia sorry
Old Feb 28, 2020 | 10:31 AM
speedman's Avatar
speedman
I am still hoping someone has a vacuum line diagram for my '05 MCS
Old Feb 28, 2020 | 10:35 AM
Derek86's Avatar
Derek86
Are you chasing a vacuum leak?
Old Feb 28, 2020 | 10:57 AM
cooper48's Avatar
cooper48
Check out www.realoem.com for illustrations of the vacuum lines.
Old Feb 29, 2020 | 02:12 PM
speedman's Avatar
speedman
I have been chasing a P1498 code for months I have tried everything except replacing all the vacuum lines.
Old Mar 1, 2020 | 08:25 AM
Derek86's Avatar
Derek86
Have you had it smoked or gone in there with some starting fluid to find the leak? Rather than just throwing parts at it.
Old Mar 1, 2020 | 05:08 PM
speedman's Avatar
speedman
I have sprayed starter fluid on almost the entire engine in hopes of some of the stuff getting in a crack or leak while motor is running. I am so tired of get less gas mileage and having the code light up my dash. I hate this code
Old Mar 2, 2020 | 04:18 AM
Derek86's Avatar
Derek86
I understand, I chased one for a while too.
pdcleven
Oct 17, 2019 09:05 AM
shanksamillion
Nov 2, 2018 11:14 AM
Khai
Jun 1, 2017 08:37 AM
screwed36coupe
Sep 14, 2013 03:35 PM
