Suspension Rear Upper Shock Mount Bushings
Old Feb 19, 2020 | 08:50 PM
JAB 67's Avatar
JAB 67
2004 R53, 160K. I am rebuilding my suspension, front and rear. Powerflex makes a "rear upper shock mount bushing." It sells for $60.00+. Of what benefit is this? In the rear I have already installed new shocks, mounts, bump stops, pillow bushings, sway bar end links and sway bar bushings.
Old Feb 21, 2020 | 09:05 AM
veedubpat's Avatar
veedubpat
Bit stiffer mount above the damper and spring assembly, between the body and assembly. It'll help tighten things up, but the value is really going to be up to you. Is $60 worth chasing the best that your mini can be? If yes, buy it. If no, eh, it'll be fine. I have them, but eh, I'd spend the money elsewhere if you already have new ones in there currently.
Old Feb 21, 2020 | 11:51 AM
cristo's Avatar
cristo
Alliance Member
Some have had problems with
strut shaft binding with poly
rear upper shock mounts.
Not sure if the Powerflex ones
are softer or better designed
than the Madness ones discussed
in the link below.
On the other hand, Powerflex
front control arm bushings are
a must, at least after the oem
ones die (which usually doesn’t
take very long).
https://www.northamericanmotoring.co...ngs-great.html
Old Feb 21, 2020 | 04:58 PM
cooper48's Avatar
cooper48
Be aware that switching to poly bushings will reduce flex but increase both vibration and noise.
JAB 67
Feb 6, 2020 08:36 AM
silence2-38554
Nov 12, 2015 09:39 AM
Mindspin311
Suspension
Apr 24, 2013 08:19 PM
davisflyer
25
Feb 17, 2013 05:44 PM
bobbyharr883
Classic Mini Talk
May 28, 2009 07:18 PM
