USB / Aux-In Socket
Old Feb 19, 2020 | 06:17 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
USB / Aux-In Socket
How hard is it to replace the USB / Aux-In socket?
And, how do I know which one I have? -
https://www.realoem.com/bmw/enUS/sho...diagId=61_2666
I "Think" I have an issue with the aux-in part of the module. Sometimes the sound will be muffled or only coming out of one side, until I wiggle the plug in the socket. It acts like its not making full contact with the plug unless it is lined up exactly right. And, when I grab the cable to plug in my phone, it wiggles just enough in the socket to skew to connection so that I have to wiggle the connection to get the sound to play correctly. I'd like to not have to think about it every time I plug my phone into the cable.
Old Feb 19, 2020 | 05:19 PM
AZdsrt's Avatar
AZdsrt
If was me, I'd just call ECStuning, am sure they can figure it out. Then just order one from them while you got them on phone.
Old Feb 20, 2020 | 01:25 PM
Capt_bj's Avatar
Capt_bj
looking at your realoem link it appears the numbers relate to differences in the connectors on the back. I'd pop out the old and CAREFULLY match what I see . . . .
This 'should' pop out from the front with the use of something to gently apply pressure. A 'trim tool' is simply a thin but strong piece of plastic to wedge in the slot and allow you to pry ..... there are substitutes .....
One popped out you disconnect the cables . . .
Old Feb 20, 2020 | 01:29 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
If it does just pop out, I can give it a try... Can anyone confirm the USB socket will just "pop" out from the front of the panel with a trim tool?
Old Feb 20, 2020 | 01:33 PM
Capt_bj's Avatar
Capt_bj
the pictures show the piece is just held in with plastic tabs .... it will pop out
p.s.
I presume you have eliminated any possibility it is the cable or the connector on the phone . . . . changed cables, tried a different phone/device
and it is possible it is a bad connection on the back of the part ... once you get the part out, I'd try reseating the connections on the back first . . .
Old Feb 20, 2020 | 02:56 PM
We have seen some the backs wiggle loose, connection pops off, and sometimes some inside goes bad (must be a connection or resistor). To match up the ones you have with the year and model, you look at the front and the rear of the unit. Sometimes the front are the same but MINI changed the pinout plug or the plug shape itself. MINI had so many versions and revisions of these things, its hard to match sometimes.
Its just pops out, use a little flat head you have for eyeglasses and such.
Old Feb 21, 2020 | 10:11 AM
Lipofskyphoto's Avatar
Lipofskyphoto
Very easy to replace the AUX in. Pull the unit out and remove the connector.
You may want to try spraying electrical cleaner into the jack hole, or inserting an isopropyl alcohol soaked Q tip into the hle to clean it.
Old Feb 21, 2020 | 01:23 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Thanks for the help. It’s not the cable or the rear connector, because when the signal goes out, I can wiggle the cable jack and the signal comes back.
Old Feb 21, 2020 | 06:43 PM
dube53's Avatar
dube53
There is no way to pop out the unit from the front. The console need to be remove to access the clips from the back. I have been told this is a big job also because some dash trim pieces need to be removed.
This has been confirmed by another poster here as well as the dealer when the question has been asked. I have a similar intermittent problem with the Ipod connection.
Old Feb 22, 2020 | 04:39 AM
Lipofskyphoto
With respect, Dube, you could not be more wrong.
I've removed the jack and center console multiple times.
I just went out to my car to see if I was hallucinating, but apparently, I'm not. I popped the jack out in less than a minute.
The Aux jack easily pops out from the front. Gently pry under the two edges on the long side. Remove the connector carefully and make sure that you don't let it slip back into the console. If cleaning it doesn't fix the problem, check local used auto parts yards. You can pick the jack up for very little$$. Of ten, they will let you remove the part, which you can now do easily.
As for removing the console, it's a very simple job that does require removing a number of trim pieces. Have a Torx T20 (google it if you are unsure) handy.
These instructions for Pelican are really good.
https://www.pelicanparts.com/techart...eplacement.htm
Old Feb 22, 2020 | 08:59 PM
dube53's Avatar
dube53
I tried before to remove it without success. There is no space on both side to even insert the smallest screwdriver without marring the trim piece.
Furthermore, mine is located on the bottom of the console and not on the side as most models. This is the reason why the console need to be removed on some models. I bought a Bluetooth device for my Ipod and it fixed the problem.
SmittyRN
Jan 9, 2019 09:47 AM
Johnny Danger
Nov 19, 2016 07:51 PM
kevinlhr310
Jun 11, 2015 11:43 PM
TJunkers
Navigation/Audio
Jan 29, 2012 04:50 AM
s501435
Oct 16, 2008 04:29 AM
