R50/53 Gen 1 pre modification oil filter cap.( R50 )
Old Jan 29, 2020 | 03:00 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Well I'm in a little conundrum. My oil filter housing is missing the plastic portion of the filter mount. Really do not want to change the whole filter assembly. Anyone have one lying around?
Old Jan 30, 2020 | 08:16 AM
JABowders's Avatar
JABowders
Veteran: Army
Thy this to find the exact part you need ...
https://www.realoem.com/bmw/enUS/sho...diagId=11_3762
then check around from our sponsors for help getting the exact part and if you need to replace the the whole assembly these guys might be able to help...
https://www.allmagautoparts.com/coll...22-r50-r52-r53
Best of luck.
Motor On!
Old Jan 30, 2020 | 10:11 AM
lotter1's Avatar
lotter1
What piece are you missing? The filter cage or the drain back plunger? Or something else?
Old Jan 30, 2020 | 11:12 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Plastic cage. Have spring .
Old Feb 9, 2020 | 06:45 AM
booyah93's Avatar
booyah93
Looking at my oil filter from the outside I don’t see a plastic cage. The only plastic I know of is on the inside.
Old Feb 9, 2020 | 06:48 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
This is the style I have.
The filter are getting harder to find. Trying to avoid swapping out oil filter housing assembly.
Euphonium
Jan 29, 2020 07:34 AM
sparkyj
Aug 11, 2016 08:30 AM
bcc101
Jan 8, 2016 02:58 PM
sparkyj
Nov 29, 2015 09:03 PM
Omer Humayun
Cooper (non S)
Jun 18, 2014 12:02 PM
