Cooper (non S) Modifications specific to the MINI Cooper (R50).
Better oil filter?
Old Jun 12, 2014 | 08:59 AM
Omer Humayun's Avatar
Omer Humayun
Better oil filter?
Is there one for the R50?
Is there a point to even searching for one, as it seems the OEM one is good enough?
Old Jun 12, 2014 | 09:29 AM
CoolioMcPimp's Avatar
CoolioMcPimp
I'm not sure who carries Mini Oil Filters, but I like to think FRAM or Royal Purple make good Oil Filters along with K&N. Although I'm not sure how the OEM one compares to those.
I also feel like an oil filter will not have an obvious difference without some aftermarket mods. For a daily driver I'm not sure how important a "better" filter would be.
I'm just basing this off of what I have seen in other cars I've owned. I don't know how this information relates to the Minis.
Old Jun 12, 2014 | 10:38 AM
We have the Mann Gen 1 Oil Filter in stock or the MINI Genuine Filters just encase you are still looking for one. Or a couple. When you install the oil filter housing cap on the housing , it might take a couple times to get it on straight so you don't cross thread. Also watch the O-ring, I put a little oil on the O-ring then install on the housing cap, so it does not catch dry on the sides and then works its way out and slicing it causing a leak. You don't know till you feel a like rubber sticking out near the housing lid, housing base seam.
Mann Filter with O-ring Part number 11427512446
http://www.ecstuning.com/Search/SiteSearch/11427512446/ES257649/
Or
MINI Genuine Filter w. O-ring part number 11427512446
http://www.ecstuning.com/Search/SiteSearch/ES24009/ES24009/
We also have them is 5 packs. So you can stock them for your next oil change or maybe help out another MINI owner with there oil change.
Mann Oil Filter 5 pack part number 114275124465PKT2
http://www.ecstuning.com/Search/SiteSearch/114275124465PKT2/
or
MINI Genuine Oil Filter Kit. 5 pack Part number 114275124465PKKT
http://www.ecstuning.com/Search/SiteSearch/114275124465PKKT/
Old Jun 12, 2014 | 11:28 AM
rckrzy1's Avatar
rckrzy1
I would not use any Fram filter on my lawnmower. Tests showed they did not filter near as good as others.
Old Jun 12, 2014 | 11:37 AM
ZippyNH's Avatar
ZippyNH
+1
FRAM once had a good product....but cost cutting to be the volume leader at the "bigbox" stores and lack of investment has left them at the "back of the pack" on almost EVERY oil filter test done in the past 10 years....the filters are just JUNK...lowest of the LOWwhen cut open or tested....
But folks still remember the name, the advertising, etc....
My suggestion...Buy OEM or MANN, some like others...but hard to go wrong imo WITH EITHER ONE.
Old Jun 12, 2014 | 05:55 PM
Omer Humayun
Or
or
Is the MANN better than OEM? Judging by the pics, it does look like a better quality product.
Do you ship to Canada?
Old Jun 18, 2014 | 10:17 AM
They are both good, its what you perfer. I used them both with no problems.
Yes we ship internationally.
Old Jun 18, 2014 | 12:02 PM
gknorr's Avatar
gknorr
Just so you know, the OEM filter is the Mahle OX 175. The MINI filters even have "OX175" printed on them. The Mahle filters are pretty widely available. They're high quality and low cost - the only filter I'll probably ever use from here on out...
I agree with what the others have said about Fram filters - I ran across something online a while back that compared a bunch of different oil filters. The Fram was one of the few that had completely failed by the time for an oil change. The OEM filters are always among the best.
Kimolaoha
Jul 5, 2023 01:04 PM
devicemanager
Jun 17, 2016 06:18 PM
Chasp
Aug 25, 2015 06:44 PM
Chasp
Aug 22, 2015 01:26 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
