JCW misfire P302, 304
Old Jan 26, 2020 | 02:52 PM
gimmea250swb's Avatar
gimmea250swb
My engine was replaced within the last 5000 miles. The plugs were new, I believe the coils were not replaced.
The chassis has roughly 127k miles. The car started misfiring two days ago and now will not idle. Error codes indicate misfire on 2nd and 4th cylinder. I replaced all 4 coils. The 2nd coil was corroded with what looks to be rust. I replaced the plug in the 2nd cylinder only. There’s still brown dust down the tube. I’m not sure if the coil requires some kind of connectivity down the tube. The car will not idle and still sounds like it’s misfiring.
can anybody help?
Old Jan 28, 2020 | 06:25 AM
MiniToBe's Avatar
MiniToBe
maybe the injectors are dirty or were not connected tightly?
Old Jan 29, 2020 | 05:20 PM
gimmea250swb
Thanks, I think you may have been on to something. I fiddled with the plugs and coils several times. Started the car and it had the same symptoms. On the last try it ran for a couple seconds and then all of a sudden it stopped. It's been running good since. Maybe a clogged injector cleaned itself out...who knows. Thanks for the reply!
straightgains51
Oct 30, 2019 04:04 PM
James Michael
Oct 17, 2019 11:49 AM
HorizonBLueN18
Jan 5, 2016 02:47 AM
Z06C5R
Oct 30, 2008 05:44 PM
shamus
Sep 3, 2008 07:20 PM
