HPFP Adaptor
Old Jan 13, 2020 | 01:31 PM
skerryj's Avatar
skerryj
HPFP Adaptor
Hi all,
Hoping someone could chime in and give me some much needed advice. The HPFP on my wife's 2013 Mini Cooper S failed over the weekend. The shop we brought it to is claiming that the only part they can find is $1400 and a week out. On top of this, they are claiming that they do not have the correct software to "reprogram" the car after installation. According to the research that I have done, I don't see why any programming would need to take place. Am I correct here?
I typically fix all of our vehicles myself but I am a little short on time so I figured I would let a local shop take care of the repair. After hearing this news from the shop today, I am considering taking on the job myself. I went on ECS and found a pump for $212 but they are saying that I need an electrical adapter as well. My problem is that I cannot seem to find any information online about this adapter and how to install it. Is it as simple as it looks or am I missing something? Links to both parts from ECS are below. Thank you in advance!
Pump https://www.ecstuning.com/b-bosch-pa...518605102~bos/
Adapter https://www.ecstuning.com/b-genuine-...r/12518638006/
Last edited by skerryj; Jan 13, 2020 at 01:45 PM. Reason: forgot to include links, added model year
Old Jan 13, 2020 | 02:26 PM
https://www.northamericanmotoring.co...r56-jcw-6.html
Their was info from another member here^^ but it was edited out?
Pretty much if you have that design Bosch HPFP unit you will need to used the adapter 12518638006 for 3/2012 to 3/2014 production.
https://www.realoem.com/bmw/enUS/sho...07#12518638006
If I find a DIY on that model and wire i will post up.
Old Jan 13, 2020 | 02:45 PM
skerryj's Avatar
skerryj
Thanks for the reply. Where does the other end of the adapter terminate? Also, do you know if there is any "reprogramming" that needs to be done?
Old Jan 13, 2020 | 04:49 PM
Lou@Prototype-R's Avatar
Lou@Prototype-R
Vendor
No reprogramming required. The HPFP operates on a closed loop system. The DME request the amount of fuel pressure required via PWM signal to the pump, then monitors rail pressure to adjust as required. The instructions for replacement of the pump are attached. I would probably clear the adaptations... but that's just me being picky.
File Type: pdf
Custom tuning solutions for BMW & Mini.
Old Jan 13, 2020 | 05:24 PM
skerryj's Avatar
skerryj
Thank you! Do you know anything about the wiring adapter? Do i just cut off the stock male end and splice in the adapter?
Old Jan 13, 2020 | 08:52 PM
Lou@Prototype-R
Vendor
I don't see any differences in the wiring diagram so I would say yes. Just match pin 1 to pin 1 on the connectors and splice the wires accordingly. I would either solder and heat shrink, or use an environmental splice and a heat gun so that corrosion doesn't cause an issue down the road.
Old Jan 14, 2020 | 06:00 AM
MiniToBe's Avatar
MiniToBe
Did you call the dealer to see if there is some sort of warranty that covers the pump?
I thought this pump is not prone to failure and more reliable that the Continental pump installed on the pre 2012s.
Stokersrule
Feb 16, 2020 06:17 PM
Grusvag
Dec 21, 2019 05:25 AM
Jennifer Kintz
Sep 3, 2019 06:57 AM
a4dude
Jan 28, 2016 12:38 PM
mini_mini
Apr 4, 2013 06:11 AM
