R50/53 Oil catch can info needed , I think mine is wrong
Old Jan 9, 2020 | 05:47 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
My car came with an occ on it..I don't think it's on correctly as I've never had 1 drop of oil in it..
mine runs off the right side of the valve cover and intersects into another line that goes down under by the intake ..I never seen one here ,only ever off behind the pcv valve ...is mine on incorrect ?????
Mine comes off the crankcase vent hose not the pcv valve hose ...wtf???
Old Jan 9, 2020 | 06:25 AM
BlwnAway's Avatar
BlwnAway
Yes, someone installed it wrong, see this thread:
https://www.northamericanmotoring.co...teresting.html
Old Jan 9, 2020 | 06:28 AM
SupeR53's Avatar
SupeR53
That doesn't sound right, can you supply a picture for reference? The DPO of my '05 MCS removed a catch can installed by the first owner and it was mounted in front of the passenger (LHD-US) in the fresh air bucket and routed form the PCV as you said.
Old Jan 9, 2020 | 06:49 AM
MiniManAdam
Community Builder
Lol I'm sure it's wrong . It's coming off my valve cover and intersecting my intake geeez....
do I just hook that line up from the intake back to the valve cover ? I'm going to remove it and install it correctly..idiots.
now,should I have the filter on the catch can to vent ? I've never seen a vented can on an R53 before ,or should I keep it sealed like I have it ( I removed the filter already as it was causing a vacuum leak where installed )
Old Jan 9, 2020 | 06:57 AM
MiniManAdam
Community Builder
Ok...Soo.
Correct me if I'm wrong .
I run the vacuum line from the right side of the valve cover to a T and I also run a line off the pcv valve into that T and have it connect to the oil catch can . Then I run the out line of the oil catch can to the intake tube ?
Old Jan 9, 2020 | 07:43 AM
BlwnAway's Avatar
BlwnAway
No.
Read the other thread completely, it will tell you everything you need to know.
PCV to Catch Can, Catch Can to PCV Vacuum Line
No T's at all.
Also, No, no filter.
The Mini system is a closed system, it requires vacuum and pressure.
Old Jan 9, 2020 | 08:21 AM
SupeR53's Avatar
SupeR53
BlwnAway has it right, relocate the OCC to the passenger's side ventilation pocket, run hose from PCV to catch can inlet, outlet directly to PCV.
Old Jan 9, 2020 | 08:29 AM
MiniManAdam
Community Builder
So it just basically puting the can inline behind the pcv valve then ??? Just having to reroute lines then..
also should I just leave this catch can in place where it is ? It didn't catch any oil 6 months of owning the car buuut it did have a filter in it screwing up vacuum so as of yesterday I capped off the filter .
Old Jan 9, 2020 | 10:12 AM
BlwnAway's Avatar
BlwnAway
Actually, that side doesn't matter, the driver side outlet of the rocker cover is actually just a filtered crank case vent to open air, that's why you haven't had any issues, but also no oil residue.
Old Jan 9, 2020 | 11:05 AM
SupeR53's Avatar
SupeR53
Location of the can doesn't matter, I just like a clean engine compartment, but yes, it just goes inline between the PCV and the intake (where the PCV attaches to now).
Old Jan 9, 2020 | 11:34 AM
MiniManAdam
Community Builder
Thank you guys ..I will be correcting this soon
Old Jan 11, 2020 | 09:54 AM
BlwnAway's Avatar
BlwnAway
This thread just got a bump:
https://www.northamericanmotoring.co...an-how-to.html
Figured it couldn't hurt to give it mention here also, really good instructions.
Old Jan 11, 2020 | 04:02 PM
MiniManAdam
Community Builder
I checked my oil catch can and it's not labled in/out...
Should I assume the left port is the in ? If I open it ,is there a way to tell ?
Not only is it in the wrong area on my car I'm almost positive the lines are wrong in it too. The right side of the can goes to the valve cover and the left side to my intake .. ( just tonight I switched them around and installed new pcv valve )
Old Jan 11, 2020 | 04:37 PM
BlwnAway's Avatar
BlwnAway
Unfortunately they are most likely not all the same, but mine is:
(looking from the top, as a U shape)
Right Side - In from PCV
Left Side - Out to vacuum
As long as the system is sealed as it should be, it won't really hurt anything if it's backwards, this is an advantage to a sealed system. It really just needs 2 open ports and shouldn't need to be directional except for some possible internal screening. (Which should of course be on the "IN" side of things.)
But again this could easily vary from mfg to mfg.
Old Jan 20, 2020 | 10:54 AM
MiniManAdam
Community Builder
Ok..I fixed it..I have heard you caaaaaaan run a can out of the other valve cover to intake but it does next to nothing , that was where my old one was so that's where it stays . So now I'm running a dual can setup.
i bought a new one and installed it correctly
I'm curious to see how much oil it catches in 3k miles ..
Old Feb 17, 2020 | 03:55 PM
MiniManAdam
Community Builder
After about 600 miles of driving it's doing its job !
Old Feb 17, 2020 | 04:14 PM
Grand-Cayman's Avatar
Grand-Cayman
M7 directions here: https://www.m7tuning.com/m7-exact-fi...3-3m7303-black
Old Feb 17, 2020 | 05:15 PM
MiniManAdam
Community Builder
Lol 180$ . I don't like those ones with windows , I've seen many leak after a few years of use( not the m7,similar designed ones).
My 20$ can seems to be working just fine...the only difference between it and one 10x the price is is doesn't have an internal filter though it does have baffling to prevent sucking up the caught oil.
Old Feb 17, 2020 | 05:30 PM
Grand-Cayman
Here's what I did to my $180 can (LoL):
This is a proprietary design using rare materials that increases surface area by a factor of 10x and allows a laminar-to-turbulent boundary layer to deposit more particles haha. So, this can could bring $300!
Old Dec 19, 2020 | 01:19 AM
jk6672's Avatar
jk6672
Since you are now running a dual occ, I’m curious if you have seen anything in the left side occ. I installed a tvs900 sc and figured this is the perfect time for a occ before I button it all up.
Old Dec 19, 2020 | 01:22 AM
MiniManAdam
Community Builder
I never ended up keeping on the one on the drivers side , it never got any oil in it , thats where it was when I got my car but thats not the correct spot . The pic above is the correct spot and I DO catch oil in it now.
Old Dec 19, 2020 | 01:30 AM
jk6672's Avatar
jk6672
Thanks. No problem with it mounted there? I’ve been reading what I can find and it seems some believe it’s too hot in that location and vapor stays vapor and defeats the purpose. I can see it’s working in your photos, but wonder if it could catch more in a different location. I ordered a BSH can, and if it fits, the plan is on the cowling side, all the way to the far right.
Old Dec 19, 2020 | 05:39 AM
Benjamin Tatham's Avatar
Benjamin Tatham
I have heard a lot of people say this location is too hot. I guess I don't really know because I am not pushing my car and getting everything really, really hot for extended periods of time, but I mocked up the same can in the same spot and you can put your palm to it after the hardest driving I do- not hot at all. I am not saying this is the right spot, but why does everyone think being right there heats it up so much?
Old Dec 19, 2020 | 10:18 AM
jk6672's Avatar
jk6672
I understand what they are saying. Logically if the can is hot enough to boil the content the vapor continues down the path and renders the can pointless, but you have physical proof it does accomplish its task in this location. I’ve wondered about this theory because you’d think if true, the antifreeze reservoir would boil too.
Old Dec 20, 2020 | 07:31 PM
Serafin's Avatar
Serafin
Here you go. I have it installed passenger side cowl. There’s a bolt sticking out already, i made an L bracket and added a nut.
Billiho
Jun 3, 2019 05:44 AM
Jpainter187
R55 :: Clubman Talk (2008+)
Feb 16, 2017 05:14 PM
bobzdar
Oct 16, 2013 11:02 AM
jlm
Oct 16, 2007 10:28 PM
norm03s
Feb 15, 2004 06:30 PM
