Can anyone help me identify this sensor/connector
Old Jan 8, 2020 | 02:31 PM
MrRowleyBri's Avatar
MrRowleyBri
Hey everyone. Happy Wednesday. I wondering if someone here can help me identify this sensor. This is a new car (to me) and I'm still getting to know her. Recently when I was looking over the engine bay I noticed that this particular sensor wasn't even plugged in. On further inspection it is cracked and needs to be replaced. Is this maybe a heat sensor? Here are some pics that move from general location to very specific location.
Thanks in advance!
Old Jan 9, 2020 | 05:41 AM
MiniToBe's Avatar
MiniToBe
On the N12 engine (2007-2010 base model), this would be the oil pressure sensor. It is as seen, a one-wire plug.
Old Jan 9, 2020 | 06:59 AM
MrRowleyBri
Perfect! Thanks a lot. That will help me chase down a replacement connector.
Old Jan 10, 2020 | 08:42 AM
Yep and its here: https://www.ecstuning.com/Search/Sit...h/12617568481/
Old Jan 10, 2020 | 11:22 AM
MrRowleyBri
Thanks for the link. Your response made me realized I needed to add one more detail. The piece that screws into the engine appears to be fine (though I'll probably replace it too). It's the connector on the wiring harness that is cracked. Do you have something for that?
Thanks again.
Brian.
Old Jan 10, 2020 | 11:26 AM
Yep, thought it was the sensor side: 12527542850
https://www.ecstuning.com/b-genuine-...h/12527542850/
and then is you need the new little metal taps, sometimes hard to get out. Pull that blue tab to the side and try to slide the pins out.
https://www.ecstuning.com/Search/Sit...h/12527543260/ x 1
Old Jan 10, 2020 | 11:37 AM
MrRowleyBri
That looks like what I need. Mine is only a single wire though. Am I missing something?
Old Jan 10, 2020 | 12:07 PM
Yep, in you pic you just use the ones side. You can see in that picture you posted, 2 pin socket but only one side has wire, i adjusted and but x 1 , sorry did not mean to put x 2 for the metal tab.
Old Feb 8, 2020 | 04:47 PM
MrRowleyBri
ECSTuning,
I got the plug and metal tab in and tried to install it, but it didn't match up with what was on my car. I've seen a few things that were cobbled together on this car so I'm guessing the one that was on there just wasn't the right one to begin with.
If you don't mind, would you give me a part numbers for the sensor, the plug to fit and the tabs as well? I'd like to order all three at once knowing for sure they'll all fit.
I'd appreciate it!
Thanks.
Old Feb 10, 2020 | 06:49 AM
Yep, someone might have tried to make something work is my guess.
Plug
https://www.ecstuning.com/Search/Sit...h/12527542850/
Tab
Sensor itself:
Old Feb 10, 2020 | 08:03 AM
MrRowleyBri
Perfect!. I just ordered. Thanks for your help!
Old Feb 12, 2020 | 08:03 AM
Awesome! Welcome.
Jeremyj
R58 :: Coupé Talk (2012+)
Dec 30, 2016 08:48 PM
amp24680
May 8, 2015 07:06 PM
Gamble_Rumble
Electrical
Mar 3, 2012 03:50 AM
jaireco
Jul 28, 2009 07:34 PM
SpiderX
Jun 30, 2005 05:48 PM
