R56 non LCI to LCI taillight swap - DIY
Old Dec 3, 2019 | 07:54 PM
GT350's Avatar
GT350
My car is 07, have a spare LCI taillight from my 13 GP, decided to do a swap w/o programming.
Non LCI to LCI is NOT a direct plug and play, you can program it for sure. but you can also switch wires if you don't want to learn programming just for that. This is not a step by step, just to point out some key things that people may curious about.
- No wire cut is needed, the wire can be pulled out and re-insert to the connector. so you can even make the LCI as a blinker.
- Once the headlight on, Pre-LCI has 2 bulbs light on, they are the same bulbs for brakes. For LCI taillight, headlight on, LCI on. there are 2 different bulbs for brakes only. This is the main difference other than the sequence of the wires. In my case, the upper brake light from the LCI taillight isn't wired.
- You will need to add a reverse light, this is another difference between pre-LCI and LCI. I put 3 LED & wire to 1 of the reverse light wire.
Left is Pre-LCI, right is the LCI.
# 1 to 6 is sequence of the wire in connector. L to R. For example, #4 for pre-LCI is lower brake light, but for pre-LCI is upper brake light (I leave it open to disconnect upper one)
Do NOT cut the wire, easy to switch
New reverse light.
cleon101
How to
May 30, 2017 08:35 AM
Jeffsmashkot
May 6, 2010 05:16 AM
EDM
Sep 6, 2008 06:18 AM
fozworth
Nov 18, 2006 06:29 AM
speltzer
Nov 15, 2003 04:51 PM
