R56 Bilstein front strut won’t fit
Old Oct 30, 2019 | 11:10 AM
Frixos's Avatar
Frixos
I’m installing the OEM Bilstein front struts on my MINI, but I can’t seem to get it in. It looks like the angle is good, but when I use my jack to push up at the lower control arm, more pressure is applied but the strut doesn’t move.
any suggestions?
I have verified it is the right strut and right side, I brushed both the hole and the strut with metal wire brush and sprayed them down with a lubricant (WD40)
When I measured the diameter of the stock and this one,’it appears the Bilstein is 1mm bigger.
Old Oct 30, 2019 | 11:39 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Needs to be almost perfectly aligned, and there is a tab that has to slot into the knuckle on the back side.
Old Oct 30, 2019 | 12:12 PM
Frixos's Avatar
Frixos
the slot is correctly aligned, but it hasn’t even gotten that far in.
Old Oct 30, 2019 | 12:36 PM
iwashmycar's Avatar
iwashmycar
Maybe jack up on is as you were and tap the side of the knuckle with a hammer.
Old Oct 30, 2019 | 04:37 PM
Frixos's Avatar
Frixos
Ended up hammering the bottom of the knuckle with a big ole hammer and it slowly but surely made its way up! Thankful for this project to be done.
Old Oct 30, 2019 | 06:10 PM
Frixos's Avatar
Frixos
So I test drove it down the neighborhood street, and both front left and right now clunk. Not sure what I did.
Is it safe to drive to a shop?
Old Oct 31, 2019 | 06:50 AM
iwashmycar's Avatar
iwashmycar
if it still feels solid despite the noise, probably ok.
I assume you reinstalled the sway bar links ect? If not those might tear up some shlt.
Brake caliper bolts if you took those off.
Otherwise probably something with the top hat assembly.
Old Oct 31, 2019 | 07:24 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
My guess would be end links not tightened appropriately... Would be worth it to lift the car, take a wheel off, and check everything out. Make sure you lift both front wheels off the ground to check the end links.
Old Oct 31, 2019 | 07:53 AM
Frixos's Avatar
Frixos
Ok, I'm gonna go ahead and tighten the strut nut and hope that fixes it.
As far as the end links, I torqued them to 41ft/lb. I only loosened the upper part and not the lower part of the end links, so I didnt check the torque at the lower part of the end link. Could the lower part have been untorqued when I detached the upper part of it?
Old Oct 31, 2019 | 12:20 PM
iwashmycar's Avatar
iwashmycar
nope.
Old Nov 2, 2019 | 06:44 AM
Lancaster's Avatar
Lancaster
Since this sounds like the most challenging part of the install, perhaps it was not fully seated.
Old Nov 2, 2019 | 07:07 AM
Frixos's Avatar
Frixos
Could you elaborate on what you mean by not fully seated?
Old Nov 2, 2019 | 07:25 AM
cristo's Avatar
cristo
Alliance Member
Did you use a spreading tool on
the knuckle? I found it really
useful when I put Koni Yellow
struts in a few months ago.
This one works really well but
a 1/4 inch drive adapter is
cheaper and also works but not as easy.
Amazon Amazon
Old Nov 2, 2019 | 07:37 AM
Frixos's Avatar
Frixos
https://www.amazon.com/Schwaben-SCW3.../dp/B007WR6XVO
I didn’t! I wish I had gotten one like that. Would’ve made it a whole lot easier.
Old Nov 2, 2019 | 02:01 PM
Lancaster's Avatar
Lancaster
Sure in the image below. Perhaps the bottom of the strut was not fully inserted into the control arm (circled in red below. I believe this is what you were referring to as challenging in your first post. If it in not fully inserted and tightened, just the slighted metal on metal movement will make noise.
grueinthebox
Suspension
11
Jan 30, 2022 10:00 AM
welcha13
Oct 3, 2018 11:21 AM
keraba
Jan 2, 2016 02:11 PM
howardholton
Suspension
11
Aug 24, 2012 08:08 AM
