Anyone running 18×8.5 et45 on an F56 Hatch?
Looking at some Rays Volks wheels, my ideal size is 18x8 et45, however they dont quite do that size, they can supply either:
- 18×8.5 ET42
- 18x8 ET50 - Dont think these will clear factory JCW brakes/struts without a 5mm spacer
- 18×8.5 ET42
I looked it up and I think there is a user here that is running Volks in an 18x8.5 et 42. Here is the thread: https://www.northamericanmotoring.co...on-t-they.html
If you want to play it safe, go with the 18x8 +50. Yeah you'll want a spacer, not only to get further from the strut, but more flush with fender. But you can fine-tune it and get the exact fit.
If you're planing on camber plates, well then I'd guess (just a guess) that you could make the +42 work. The examples I see on that thread and others look like too much poke in the front. I bet they rub, even at stock height, if the car gets driven hard at all. If you lower it, for sure rubbing.
And of course, tire width will play a major factor here.
www.willtheyfit.com
www.willtheyfit.com
R53hyperblue
Wheels/Tires/Brakes
Nov 8, 2019 08:58 AM
