F56 wheels on an F54
Old Jul 18, 2017 | 06:28 PM
miniluvrF54's Avatar
miniluvrF54
Hi everyone!
I've been trying to research this issue and I *think* I've confirmed that F56 wheels will fit an F54, but every thread I find on the issue doesn't seem to come to full resolution.
The bolt pattern is the same at 5X112 and from what I've been able to research the backspacing and offset are the same as well. The only thing I can't seem to get clarity on is the center bore which one thread (different forum) initially indicated that they were for some reason different, but then another person appeared to claim it was indeed the same.
Can anyone put this issue to bed?
Old Jul 22, 2017 | 01:35 PM
rtowell's Avatar
rtowell
ECS Tuning lists a lot of wheels for the F54, most of which are the same as for the F56. I guess the answer is ... yes, but depending on your model there could be some differences.
Old Jul 25, 2017 | 02:13 PM
Yes, they will fit unless you have JCW brakes then you have to watch the clearance on some. If you have S and Cooper brakes your fine. We fitted allot of wheels to the F55, F56, and F54 allready. The big thing is the F54 will take larger wheels compared to the F56 in width and offset. More room. So working from F54 to F56 you might run into issues on space.
Full line here:
https://www.ecstuning.com/Mini-2017-Cooper-F54-Clubman_S_ALL4-Coupe-B46A20A/Wheels/Aftermarket_Alloys/
