R50/53 Electrical problems 2002 R50
Old Sep 14, 2019 | 11:43 AM
mattt1977's Avatar
mattt1977
Ok so the car is new to me as I got it for $500 with a blown 5 speed. The person I got it from and already dug into it and had the trans out. I put the 6 speed into it and it runs and drivers great.
Here is the issue. I think I either have a BCM issue or a grounding issue.
Problems. When I turn on the lights the passenger side works driver does not. Confirmed with volt meter. Rear also no brake lights. When I was messing with bulbs in the rear however I replaced one of the rear brake lights with a turn sig light and boom all the lights worked. Except the center brake light was very weak.
Any ideas??
Old Sep 21, 2019 | 09:57 AM
mattt1977's Avatar
mattt1977
anyone have anything
Old Sep 21, 2019 | 07:55 PM
ssoliman's Avatar
ssoliman
I’m no good with electrical. I’d say buy a Bentley manual and dig into the wiring diagrams.
sorry that’s probably not much help
Old Sep 21, 2019 | 09:05 PM
MVPeters's Avatar
MVPeters
I'd check the ground wires first - make them all bright & clean & tight.
I'd buy a handful of new, correct bulbs.
Install them in the correct positions, one at a time.
Old Sep 24, 2019 | 07:17 AM
mattt1977's Avatar
mattt1977
thanks. How many grounds does it have. I see the hood and passenger side front. Also see the rear with the taillights. Do you know the locations of the others.
Old Sep 24, 2019 | 07:42 AM
MVPeters's Avatar
MVPeters
Those are the main ones - there's a list of the others here somewhere or in the Haynes manual.
Oddly enough the battery terminals often seem to be loose, but if the car starts OK, those should be OK.
Be aware that corrosion of the tail light plugs is common, as is melted bulb holders - you may need to cut away some plastic to get at the bulbs.
On the early cars, there is a way of having only one side of the parking lights on. Make sure the directional switch is central.
I'd disconnect the battery overnight if you haven't already.
I assume you mean the high-level red brake light - that's all-LED & only replaceable as a complete unit.
"I replaced one of the rear brake lights with a turn sig light and boom all the lights worked."
It shouldn't be possible to do this as the bulbs are different. However, since you have, it probably provided the missing ground - by shorting out the two contacts on the stop/tail bulb.
Archduke Andrew
Jan 11, 2017 06:14 AM
justincummings
Oct 23, 2010 07:08 PM
Soul Coughing
Oct 21, 2010 01:38 PM
Jephen19
Dec 24, 2008 12:33 PM
