R50/53 Intake Manifold to Airbox gasket help
Old Sep 3, 2019 | 01:16 PM
Oh Six Mini's Avatar
Oh Six Mini
I am replacing the intake manifold on my 2006 R50. (The old one was removed by someone - long story.) Anyway, it seems there is a rubber gasket that connects to the airbox that the intake manifold that creates a seal between the two. That gasket has basically deteriorated on my air box. It is just a glob of sticky rubber. I have searched for a replacement, but there doesn't now seem to be one. I guess it comes attached to a new airbox, which is quite expensive and I do not need.
Can anyone confirm that the gasket is not available by itself and, if not, any thoughts on an alternative? I was thinking I'd just coat the area with an RTV gasket maker silicon. Would this work?
Here are pictures of the parts in diagram and on I found with the gasket in place.
Thanks!
Old Sep 3, 2019 | 01:52 PM
cooper48's Avatar
cooper48
I haven't found a source for that gasket. Best bet is a wrecking yard or possibly someone on this forum who is parting out an R50.
Old Sep 3, 2019 | 02:26 PM
Oh Six Mini
It is a pretty gooey mess. I don't know if it would come off of one in a salvage yard. I could probably replace the whole airbox, but don't really want to do that.
Old Sep 3, 2019 | 03:24 PM
veedubpat's Avatar
veedubpat
RTV is flexible. If you don't need that property, perhaps a different type of silicone adhesive would sort this out for you.
If it's unobtanium and it's necessary, epoxy that sucker.
Old Sep 3, 2019 | 03:38 PM
Oh Six Mini
The rubber around the hole was flexible at one time. It probably absorbs some of the vibration between the intake and the airbox. If I can't fine some kind of rubber to use, I will use RTV.
Thanks for the replies!!
Old Sep 3, 2019 | 09:24 PM
BlwnAway's Avatar
BlwnAway
Honestly, it's not even that important of a gasket since it's in pre-filtered location.
If it rattles or really bothers you, take a length of a larger diameter vacuum hose, split it long ways, and make your own gasket. You can use a small amount of silicone to hold that in place if need be.
Old Sep 4, 2019 | 05:53 AM
Oh Six Mini
It would rattle around I think if something was not around it. The vacuum hose is a good idea. I was thinking about 4M black Butyl rubber around it, but I am not sure it can stand the heat.
The Angry Pumkin
May 18, 2013 09:07 PM
thecanuck
Sep 15, 2010 07:18 PM
ortuna
May 25, 2010 06:49 AM
kenros
Cooper (non S)
Nov 6, 2007 07:51 PM
XTREEM
Oct 7, 2005 01:44 AM
