R50/53 Leaking lower radiator hose
Old Aug 22, 2019 | 07:21 AM
r53-06m6's Avatar
r53-06m6
I have an Ebay G Plus Radiator along with a G Plus silicone radiator lower hose. Ok, cheap stuff...fine.
However, I can't get coolant to stop leaking from the connection between the lower radiator hose and the lower radiator fitting. I am using a high quality breeze clamp but when pressure testing it comes dropping out. I am apparently losing coolant while driving as well.
Any suggestions on situations like this? No, I am not going to change my hose and radiator unless it was like some super last resort.
Old Aug 22, 2019 | 07:41 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
Although you say that you're already using a high quality clamp, I'd suggest trying another one just to see...
...something like ABA is what I'd go for:
After testing with an alternate clamp, if it still leaks then it's narrowed down to issues with the rad/hose itself.
Old Aug 22, 2019 | 07:49 AM
r53-06m6's Avatar
r53-06m6
Thanks, I think it is the angle between the lower radiator hose and the lower radiator which is causing the issue. How tight are you/can you really crank down on a lower radiator hose? It seems like back in the day you could tighten things until they didn't turn anymore. Do that now and SNAP.
I'll definitely try that clamp though.
jimmwaller
Jan 16, 2022 09:01 PM
Andryiakathlene
Jun 26, 2018 07:01 PM
AndyPWR53
Mar 19, 2014 04:44 PM
oliverm
17
Apr 19, 2009 11:29 PM
ice877
Feb 15, 2008 09:22 AM
