New radiator issues
Old Aug 16, 2019 | 07:51 PM
Oval55oval's Avatar
Oval55oval
New radiator issues
Gentlemen, I have put 2 new factory radiators on my 2005 jcw r53 in the last year. One month ago I put the second one on and it is leaking exactly where the other one was, looking at the front of the car, 3 inches down about 5 inches long, anti freeze is setting on the coils, very minor leak, car is not heating, but anti freeze level is dropping slowly. Sitting in garage I may see a quarter size drip on floor. Anyone seen this issue, radiator is under warranty if I want to pay mini to install, which is twice what a new radiator cost. THOUGHTS I am thinking about going to Mishimoto.
Old Aug 16, 2019 | 08:16 PM
JAB 67's Avatar
JAB 67
I am on my third Mishimoto radiator. Think about it.
Old Aug 19, 2019 | 09:23 PM
ItsmeWayne's Avatar
ItsmeWayne
This can happen, as competition in manufacturing radiators, is fierce and they just aren't made very good these days. Get another!
Old Aug 22, 2019 | 07:36 AM
DeadErnie's Avatar
DeadErnie
As somebody that needs a new radiator too, I'd like to hear what people have used. Was thinking about the CSF or possibly a nissens or behr.
Old Aug 22, 2019 | 09:22 AM
ItsmeWayne's Avatar
ItsmeWayne
The factory radiator seems to hold up well for a few years. I hate the plastic tanks on them, but the truth for me, is it works! I bought a fairly expensive all aluminum radiator and it only lasted me one year.
Old Aug 22, 2019 | 02:50 PM
maddog2020's Avatar
maddog2020
I'm glad I stumbled upon this thread. I'm about to do cooling system surgery on my daughter's '05 R53 and was wondering if I should splurge on the Mishimoto. Sounds like there's not much point, so I'll stick with an OEM-like alternative from O'Reilly - it has a lifetime warranty, although the process of replacing it is pretty painful, so I just hope the new one doesn't leak. Her cooling fan is making a heinous noise and there is coolant leaking from a few spots, so I'm going all out while I'm in there, and am replacing the reservoir, thermostat and housing, radiator, cooling fan, and all the hoses. The silicon replacement hoses are the most expensive part of the whole thing....
Ian
Old Aug 22, 2019 | 03:10 PM
ItsmeWayne's Avatar
ItsmeWayne
Hi Ian,
You will most likely need to replace the low speed fan resistor, that in within the radiator shroud. They are forever going out.
The fan speed controller lower left
Old Aug 22, 2019 | 03:13 PM
maddog2020's Avatar
maddog2020
Originally Posted by ItsmeWayne
Hi Ian,
Thanks. I assume a new fan assembly will include the controller and resistor, or is that bad assumption?
Old Aug 22, 2019 | 03:15 PM
ItsmeWayne's Avatar
ItsmeWayne
It is a bad assumption! It is not part of the fan assembly
Old Aug 22, 2019 | 03:16 PM
maddog2020's Avatar
maddog2020
Well crap. Where can I get the resistor from?
Ian
Old Aug 22, 2019 | 03:18 PM
ItsmeWayne's Avatar
ItsmeWayne
Amazon, Car Quest Auto Parts, World Auto Parts, E bay (I steer away from them)
Amazon:
Amazon Amazon
Old Aug 22, 2019 | 03:23 PM
maddog2020's Avatar
maddog2020
Thanks, I ordered one and will be replacing that as well...while I'm in there I may as well.
Anything else I should do from a preventative perspective while I have the front end off?
Ian
Old Aug 22, 2019 | 03:30 PM
ItsmeWayne's Avatar
ItsmeWayne
If you have bumper cover fog lights, it will be easy with the bumper cover off. If they are damaged, Amazon have after market and oem replacements.
You also want to look at the Vibration dampener on the front of the crank, as age makes them go bad also. ECS Tuning has a good one, if you need one. (others to, including Amazon)
You should also check the belt tensioner bearings, they should not wobble at all.
Old Sep 8, 2019 | 08:02 PM
Parker Peabody's Avatar
Parker Peabody
Original poster and someone else said they're on their third radiator... My r53 making 230hp currently is running lots of OEM parts bought through FCPEuro, 4 throttle bodies, 2 Mishimotos, 2 Waterpumps, etc. all replacements following the initial were free.. just a thought for those sick of paying for the same crap over and over. Caveat: I do all the work myself so I don't have to pay for labor.
JAB 67
Feb 11, 2025 05:17 AM
MINICS04
Oct 26, 2020 06:54 PM
Bwilliams
Apr 10, 2017 03:23 PM
Chase Lewis
Feb 10, 2017 12:04 PM
succubus
Dec 20, 2013 11:06 AM
